TC and VB upgrade questions
Ok so I am getting this trans out of a 99 and I want to put in a new TC and VB. Here are my questions:
1. What TC should I purchase that isn't extremely expensive? My power mods probably wont get more intense than what they are now. 2. I am gonna get an aftermarket VB and was wondering what the difference is between a John Woods and a BTS? Which one does everyone prefer and why? In your opinion does a new TC, VB and a Transgo shift kit sound good enough to withstand my right foot with the DP on the high settings? Thanks, Ben |
I was told by JW that the pump should be modified,don't know if it's the same stuff in tugger kit or not
I think any of the three VBs would be fine |
I'm not sure either. Anyone else have any insight on this? I want to make sure I'm not buying and installing somthing that I don't need.
IMHO, I would go with the Tugger kit. This would do the VB mods and pump mods at the same time. I would also add the 4R100-LU kit to the pump. Depending on the the pump, the '99 trans could be equipped wth this type of valve or a "pulse width modulated" valve. The LU gives a positive-type "on-off" engagement, instead of a slow "regulated" engagement. Without knowing the condition of this trans, I don't know how well it would hold up to the DP tuner and add'tl mods. I wouldn't want to lunch a trans and have pieces in my new converter. There are many good converters on the market, but many require a core. I got my triple disc billet without a core for around $900. I did all my upgrades at the time that I rebuilt mine.
I went the easy way and installed a BTS-VB. I also went with this one because I live closer to BTS then JW, and when my tranny takes a dump, I will get it rebuilt by Brian.
Originally Posted by Fire85
(Post 6129890)
2. I am gonna get an aftermarket VB and was wondering what the difference is between a John Woods and a BTS? Which one does everyone prefer and why? In your opinion does a new TC, VB and a Transgo shift kit sound good enough to withstand my right foot with the DP on the high settings? 2. I prefer the BTS one because, AFAIK, DP-Tuner has files set up for BTS but I am not sure about JW. IMO, get the VB, DP-Tuner tunes, and a 6.0 Trans cooler. You shoudl be set for trans temps. With the BTS trans and the 6.0 cooler and on stock tunes, I am about 55 deg above ambient in the summer. With the 80E tunes, I am at 75 deg above ambient because I can't keep my foot out of it. |
Another question: If I go with this transgo shift kit do I need to get a BTS or JW VB? or does the transgo make modifications to the VB to match the BTS or JW VB?
AKLIM, Thanks for remindind me about the 6.0 trans cooler. Forgot all about getting that |
(Post 6131049)
AKLIM, Thanks for remindind me about the 6.0 trans cooler. Forgot all about getting that Anytime |
Originally Posted by aklim
(Post 6131063)
IIRC, with Transgo, you will have to take apart the VB. With the BTS one, you remove the VB, replace it and forget about it.
Anytime |
JW can build his VB for DP tuners as well- he told me so on the phone. As for BTS vs. JW VB, I just heard that the price of the BTS went up to $400 which makes the JW much more enticing- not sure if it's true or not.
I'm in the same boat with my 99, I was told on another forum to get a VB AND the Tugger kit, along with a new TC. The 6.blow and 6.4 converters have a pretty good reputation and are affordable- $200 + core for the 6.blow TC. Roland- would this pump mod you speak of get rid of a long lagging shift in my 99 trans? By long shift, I mean it feels like it shifts twice between each gear. |
Factory Tech is another good VB 1997-2003 E4OD/ 4R100 Diesel Valve Body
Originally Posted by superduty4x4
(Post 6133524)
This may be an ignorant question but should I take out the sonnax shift "improver" for the new trans or is the transgo/JW VB going to be covering what the sonnax does?
Thanks to all of ya. the advice and info helps tons. Ben |
Originally Posted by mueckster
(Post 6130649)
Where did you get your TC @ for $900? |
(Post 6148940)
Roland
Where did you get your TC @ for $900? See item # 3-B near bottom of the page. I built my trans using the #K-100 kit, along with a few other parts that were not included. I had upgraded to the billet converter. |
