Portals? the good, the bad, and ugly.
Since that other thread has gone to ____ I'll start a new one.
Portals Pros and Cons? :confused: |
how about the different version? i want to know specifics about each one. i'd probably end up running a set one day if knew more about them
i have heard a lot of people doing good things with the 404's -cutts- |
great ground clearance, with minimal lift....torque multiplication......
but....expensive, more parts to break and oh...did i mention expensive? |
Yeah, I new that they were extremely expensive but give us a run down on how they work. (for lack of a better word)
Portal axles are an offroad technology where the axle tube is above the center of the wheel hub. Compared to normal layout, this enables the vehicle to gain a higher ground clearance, as both the axle tube and differential casing are tucked up higher under the vehicle.
Due to the gear reduction at the wheel which lessens the torque on all the other drivetrain components, the size of the differential casing can be reduced to gain even more ground clearance. Additionally, all drivetrain elements, in particular the transfer gearbox and driveshafts can be built lighter. This can be of use in reducing the centre of gravity for a given ground clearance. However, as it requires a heavier and more complex hub assembly, these systems can result in an increased unsprung weight and require robust axle control elements to give predictable handling. In addition, at higher speeds, the hub assembly can overheat. http://upload.wikimedia.org/wikipedi...PortalAxle.svg (taken from wikiperdia... Portal gear - Wikipedia, the free encyclopedia ). this place will be able to help you on building or buying the right parts for a portal... Home -cutts- |
check out this.... http://unimogcentre.com/unimogprinc.html#portalaxle
gives a killer run down of the basics with some sweet visuals! -cutts- |
i'll get in the specifics tomarrow, ive got a physics exam tomarrow...
Thanks for the link but I don't read German.
I had an idea of how they work. and I have an old issue of Off Road & 4x4 where they talk about it, but they only devote like a paragraph to it. |
Its essentially (from what I understand... my ex-neighbours Land Rover ran Mog axles - pictured below, before he sold it - although I have never pulled them apart), a gear reduction in the hub, with a large inner teeth gear, and a small pinion on your driveshaft.
They all have to be fully floating. They are a great design, as they put the final reduction right next to the wheel, meaning driveshafts only take a fraction of the load they take in a normal design (i.e. Mucho more hp and bigger wheels!) Less suspension lift required for ground clearance, better driveshaft angles Their only downside (IMHO) is the cost, and weight. Portal axles are pretty popular here... predominately because unimogs are popular, and we don't have the cheap access to other strong off-road axles like you guys do with Rockwells. Oh, and we are the kind of idiots that enjoy throwing 20k down on a pair of axles. The Mog ones are stronger (but this is relative... if you can break a portal axle, you are doing a good job), but the Volvo ones (out of the C303) are lighter, and better in size for most vehicles. http://www.lrocv.com.au/gallery/albu...R-DSC02796.jpg What specifically did you want to know about them? |
Tks Guy's.
Fred I don't know much about them, so when they were mentioned in another thread I started asking questions, it was suggested I'd be better off with a new thread. so I figured I'd ask and have people pool there Gray matter on the subject. What they know, what they've seen, and what they've read. Etc, Etc. and like what Fishy asked, the different types with pros and cons of each. |
Ok... I will call up my old neighbour, and see what info I can drag out of him (he used to run Mogs on his Defender... he runs Volvo's on his current Range Rover)
Sweeet, thanks Fred, you rock. :-jammin :-X25
No... I Mog :p
Originally Posted by FTE Fred
(Post 6077021)
No... I Mog :p
Hey easy callin the admin names, Especially when he's being good to me. lol
