ball joint torque specs.
Just changed the BJ's on this thing and have no idea of the torque specs... any idea?
Thanks. |
There are no torque specs on the ball joints per se as they are pressed in. I am assuming you are talking about the retaining nuts???
The lower ball joint retaining nut is spec'd at 136Nm (101lb/ft) Upper ball joint castelled nut is spec'd at the same |
