78 bronco vs 78 blazer
i have always had a buddy or three with a blazer from the late 70's, and i have always had a 78 bronco. every time i looked at the components, my bronco always looked beefier. plus until i started modifying everything, i hadn't broken a thing. not so with the blazers. i'm curious to hear what other people think. i know the frames are much weaker, but the bodies also look weaker in terms of cracking and flex. is there anything better about the blazer?
nope.......
Stupid question on a Ford site.
I don't know, I've seen a awefull lot of 70's bronco's that you could see through both sides they were so rusty.
I feel the automatic trans in the blazers were a good deal better than anything ford offered at the time. The GM HEI ignition is also vastly superior to Ford's ignition at the time. Getting a 70's ford V8 wet is always and iffy prospect. Both vehicles have their strong and weak points and neither are half as good as a Cherokee chief:-jammin of the same year. After you swapped out the ford ignition system anyhow. |
K5 Blazers were/are notorious for cracking the frame around the steering box.
Originally Posted by J..D
(Post 6022084)
I can't verify this for truth or not,but back in the late 80's/early 90s when i was in the ARMY I was told the army picked the chevy blazer and trucks because the chevies passed the tests better than the bronco did. Like i said,i don't know this for the truth,but I heard this from several different people in the 4 years I was in.
Originally Posted by FTE Fred
(Post 6028129)
Remember this is the Ford vs. Competition forum... where we present an unbiased view... so its not stupid at all ;)
Tim:-wink |
http://i195.photobucket.com/albums/z...63_400x400.jpg
Originally Posted by thorseshoeing
(Post 6040075)
In here there is no such thing as a stupid question...Only stupid people who ask them...:-D
Tim:-wink |
(Post 6040075)
Tim:-wink http://i219.photobucket.com/albums/c...l/laughing.gifhttp://i219.photobucket.com/albums/c...l/laughing.gifhttp://i219.photobucket.com/albums/c...l/laughing.gifhttp://i219.photobucket.com/albums/c...l/laughing.gif |
Originally Posted by SteveBricks
(Post 6027795)
The "78" Bronco had steering Box Issues as well..I think there were undersized as I recall. |
didn't the K5 have the crappy GM 10 bolt rear end? 10bolt <<<< ford 9"
Originally Posted by cjben
(Post 6037113)
I rode & drove many of both in those years. I owned a 79 CK20 4x4. The Chevy had much better steering, also had a solid front axle. The frame cracking by the steering box was not a problem if you checked the steering box bolts from time to time. The cause of every cracked frame (I worked for a GM dealer) that I ever saw was a direct result of the steering box bolts working themselves loose. the stress of the bolts walking around cracked the frames. I drove my 79 CK20 4x4 to 320,000 miles without cracking the frame. The Bronco did have a stiffer frame.
The 350 Chevy was faster than even the 400M, but not better. The 351/400M was a very tough engine. The Chevy had higher STOCK ground clearance. C-6 was far better auto than the Turbo 350 in the Blazer. Bronco had a nicer interior. Both were good trucks. But the Bronco would take a much better beating & hold up. These are opinions from a lot of being on & off-road with both these trucks in those years. |
You gotta be kidding me???:-hair 1978?:-huh They both sucked big time!:-missingt Was any vehicle in 1978 any good!:-huh They were both junk in my opinion as well as any 1978 Dodge Ram charger. 1978 were dark crappy days in car history! 1972-1983 were horrible years for vehicles! In 1975 the CAT was added and hp levels took a crap from there until well into the 80's. If I had to pick one I'd take the Blazer cuz of it's 7 inches of ground clearance and that small block 350 & 400 4 barrel with the turbo 400 trans was bullet proof!!! But the engines in 1978 were de-tuned pathetic weak dogs for their cubic inches!
1978 Blazer Specs: http://www.coloradok5.com/brochures/1978/blazer8.jpg 1978 Bronco Specs: 1978 Bronco Dealer Brochure | bronco.com |
