93 F150 poor mpg, miss, backfiring
My truck gets 12-13 mpg highway, misses intermittently(more under load), stalls sometimes coming up to a stop(restarts immediately), sometimes I can hear it backfire thru intake. NO POWER! I need HELP! The only code I have is from EGR, which is caused by having EGR vacuum line plugged (when plugged in it would run worse,way worse). I have changed cap, rotor, wires, wire routing, plugs, coil, ignition module, PCM, rear fuel tank & fuel pump, fuel pressure regulator, compression, cleaned throttle body & IAC motor. I have owned truck since new & it got around 17-18mpg on hwy. Please someone, anyone I need help!:mad::-banghead
Have you changed the fuel filter? It could be starving for gas.
Originally Posted by Animalistic
(Post 6007396)
check plugs.
are you positive plug wires are on correctly? which motor? they have different routings for different years for some of the v8s. |
Originally Posted by quicklook2
(Post 6007572)
check plugs.
How about a clogged cat? It may be preventing a full flow of exaust. From your original post, it looks like you have done everything you can so you may want to double check it. As QL2 says, and as I have seen many times, it is easy to cross wire the plugs. Tripple check those.
Have you checked compression? You may have a head gasket or rings going out. |
what brand and kind of plugs?
even new ones can fail, that is why i would pull them and read them. |
Loss of power could be loss of compression, incorrect timing, engine running too lean to name a few. If you did hear a backfire through the intake manifold that would indicate premature detonation, which could destroy the top half of your engine. If that is happening I would be more concerned about that then loss of engine power. If air/fuel charge doesn't always detonate when the spark plug fires or should fire, then it might detonate sometime later before the next complete cycle for that cylinder. If one cylinder is not firing at all or only sometimes, it would cause an excess amount of fuel in the exhuast some of which would get sucked up via the EGR system and end up making the rest of cylinders run to rich. Just some things to think about as you continue your trouble shooting. I have a o/2 meter in the cab of my truck which can tell me if the engine is running too rich or lean and I have found it to be the most valuable tool for trouble shooting these types of problems.
(Post 6011422)
I would check all your vacuum lines to make sure you don't have any leaks. At WOT the vacuum is low and the computer doesn't utilize vacuum for controlling it's sensors at that time so it kind of goes into a default mode. While running at cruise, you should have a good intake vacuum and the computer will be making adjustments, many of which are controlled via the vacuum system.
maybe the timing chain has streched.
seems like you tried everything. i am stumped. |
Originally Posted by MrG4x4
(Post 6012044)
Have you checked the timing? It should be set at 10°BTDC. I hope the timing change hasn't slipped, as that could be causing these issues. There are ways you can locate TDC for #1 cylinder to see if it appears the timing change had slipped, but I would first verify the timing is at spec. I agree with quick, we are running out of ideas.
there is a TSB on plug wire routing for these trucks. there should be s sticker somewhere under the hood that shows proper wire routing. there are two cylinders that fire one after the other and i believe they aare the 7 and 8 cylinders. if the 7 and 8 wires are touching anywhere you will get whats known as induction crossfire. this means that these two cylinders will fire at the same time, resulting in drivablility issues. go back and be sure you have these wires routed properly.
Originally Posted by muddyford911
(Post 6012780)
