01 expedition door panel removal
Hey guys! you are all great and give good advice!
I am still having problems getting the drivers side door panel off to see why my power window doesn't work. it is stuck in the up position. I can hear a relay clicking when I push the up/down button. thanks you! I am really a dummy when it comes to this. |
Pop the triangular plastic cover off the front top of panel (pull out at the top, then up off the door panel), there's a phillips screw underneath. Remove the courtesy light cover, there's a torx screw in there. Remove the plastic surround on the door handle and remove the bolt holding the door handle in place. I'm a little fuzzy with my recollection, but there may be another screw in there holding the panel to the door - you'll have to look. Lift the panel on the armrest housing the window and door lock switches and unplug. Panel slides up to remove (it uses hook style rather than push in retainers). Mind the wires to the exterior mirror switch (unplug). Also remove the courtesy light wire (turn and pull).
