does this look like a good list
2950.00 racer x trans with converter
208.00 deep trans pan discountpowerparts.com 49.99 cat delete pipe discountpowerparts.com 255.00 guage set beansdiesel.performance.com 58.00 guage pod beansdieselperformance.com 85.00 trans cooler whodathought fte 3605.99 total price plus shipping and cores i already have the dp and i figured it would be easier to replace the cat pipe (whats left of it) now then wresetle with the old one. and the guages to protect what i just spent all this money on. any input. any one know of any better deals going on? thanks, dan |
my only questiosn are what guages from beans? isspro's?
Only thing I would say is skip the deep trans pan. Not needed.
you can get the 4r100 pan from ford for a few dollars, last time i checked i think it was only 30 or 40 bucks and it comes with a drain plug
gauges will be the ultralite series boost egt and trans temp. i guess ill use the extra 200 from the trans pan for a service on the engine and trans from royal purple. thanks guys
i would get the isspro's from dieselmanor. they are excellent gauges and match the stock instruments perfectly.
they dont show them for obs. just superduty
thats just the kit, they have the pod and you order the gauges, it costs about 300 for everything and they are MUCH better gauges
sweet thanks for the input
For 2 dollars less you can get a aluminized steel delete pipe. I know the 2 bucks aint much but if the aluminized steel will keep the rust away a little longer you might want to go with it.
http://dieselperformanceparts.com/products.cfm |
Ultra lites match perfect if you have one of these (C2 even better!)....
http://inlinethumb47.webshots.com/28...425x425Q85.jpg |
ah but i dont have one of those....lol but if i did they would look ok, but doesnt isspro have white faced gauges? i just like the experiences i have had with the isspros. all positive so far, they are put together very nice and i like the amplifier box set-up, the egt and trans temp gauges are much more responsive in my opinion
updated list with a local guy doing the labor for 200 inside the trans. and me doing the install
749.99 armor package racerx 469.99 ultimate rebuild kit racer x 595.00 triple disc converter racer x 195.00 custom valve body racerx 103.99 tugger shift kit racer x 85.00 whodathought tranny cooler 49.99 cat delete pipe discountpowerparts.com 255.00 guage set beansdiesel.performance.com 58.00 guage pod beansdieselperformance.com 2591.96 total price plus shipping and converter core and labor 587.85 true trac limited slip ringpinion.com this option leaves me enough to go posi too. no more one wheel peel....woohoo carlisle burnout contest here i come.... |
