CEL Paper Clip Codes?
1996 F150 4.9L EFOD
CEL is on and I want to know if anyone knows a link that shows how to pull the codes with a paper clip? I have searched several sites, but it seems the pulg configuration on those sites does not match mine. All the sites show a sort of triangle shaped pulg with an addtional single connector. Mine is a rectangle with two rows of contacts. 3 on first, 4 on second, no additional connector? Thanks in advance... JJ |
Some 96s might be OBDll if sold with CA emissions. Most of these are MAF too. The OBDll connection is inside the cab on the lower dash panel.
regards rikard |
my truck was made is Missouri but shipped here in NC. I have the OBDII as well. you can pick-up a tester at autozone for like $70-$200 Depending on what you want.
Yeah, there is a real good chance your '96 is OBD-II. If that's the case, many auto parts stores will read your codes for you for free.
Jason |
All 96 F150's were OBD-II, regardless of whether it was California emissions or Federal. It was only the trucks over 8500 lb GVWR that did not have to comply with OBD-II in 96.
Well, I consider 100% "a real good chance". :-D
Jason |
