I always wondered why my kids slam the doors all the time.Now I know, but I think I'll keep yellin' at 'em for it anyways.
I pulled my driver side door apart and found a broken cable. Find it hard to believe Ford charges $180 for a new cable!
https://www.ford-trucks.com/forums/p...ictureid=90411 https://www.ford-trucks.com/forums/p...ictureid=90410 |
For the past several months mine wouldnt open so I took the door panel off and unhooked the cable housing from slot, leaving the end attached to the door handle. If I grabbed the cable housing and pulled up on it it would open the door, but it is ugly with no door panel. The cable finally broke a couple weeks ago so I've been putting the window down to open the door from the outside. Yesterday I took a steel rod I had (part of an Aanderson window I worked on), welded a 90deg piece on the end and atached that to the door latch. I ran it through the hole where the door lock rod goes (removed that)... put the door panel back on and stuck a screwdriver handle on my new door latch. Now I just reach back and push down on the handle to open the door, I can even do it with my elbow. I know it's a total jerry-rig... flame me if you want, but it works for those of us without $180 to throw at something like that.
Originally Posted by bashby
(Post 11299398)
... I know it's a total jerry-rig... flame me if you want, but it works for those of us without $180 to throw at something like that.
Originally Posted by F250F250F250
(Post 11299586)
You'll get no flames from me. After one day of driving around and having to get out on the passenger side, I am ready to call Jerry in to rig me something up!
Ford pick up truck door latch cable
Dorman 924-300 Inside Door Latch Cable Rod | eBay
$19.95 and free shipping sure beats the $180 Ford wants |
The $180 from Ford is not just the cable. It's only sold as a latch, cable, and door handle control assembly.
My dads 96 f350 pass door was goofing up so I got a cable assy (latch and all), but when I took it apart the sheet metal on the door was torn, like others have had happen, so a washer and some welding fixed it for free. Moral of the story... check it out before you buy parts, now I have to return the part and they had to order it, so I'll probably get hit with a restocking fee.
Originally Posted by country0001
(Post 5755057)
Try lubricating it, that worked for my 92
My 96 was just gummed up with dirt and old lubricant and the inside handle wouldn't budge. Spraying a lot of penetrant/lubricant through the gap in the door panel where the door handle comes through, and spraying the door latch area, freed it up completely. Took door panel off and cleaned it all up properly later. If you're lucky, that could be all that's wrong. |
Does anybody know if I can buy just the door handle assembly? If so, where from? The hole for the pin on the cable bracket is wallered out, causing my handle assembly to not open the latch.
https://cimg9.ibsrv.net/gimg/www.for...b3889e1fa3.jpg |
Originally Posted by Doc150
(Post 11173449)
I'm working on my 1994 F-150, the passenger door handle won't open so I took off the door panel and pulled on the handle to see if I could get it too work, it just snapped off leaving a big hole.. what can I do??
