Door Electrical Issues, please HELP!!
I am have alot of trouble with electrical problems in my 2005 fx4 f150.
My drivers side door power locks, windows and mirrors are not working. Using my key fob, the doors will lock. My sunroof still works. The passenger side door lock still works, but the window button doesn't. Also when i shut my truck off remove keys from ignition, and lock doors, my radio will continue to stay on. I have read through many posts and haven't seen anyone with all these issues at once. My door window controls, at first would work some of the time, but now nothing works at all. So i was assuming it wasn't a fuse, maybe a relay or something? not really sure what the problem could be? Any help would be apreciated!! |
I’d suspect chafed wiring in the door.
As screwy suggests, first look at the wiring boot on the door and see if you see any damage, cut in the rubber, etc.. I know we all hate taking our vehicles to the dealers, but you may want to take it there and have them see if there are any codes stored in memory. I'm not sure if the auto stores can pull codes other than the pcm codes, but since everything is on the can bus, each module has a self test and they could go into command mode and check the door locks, windows, etc and pinpoint the issue. Might be worth the $50-$75..
