dana 70 vs. 10.25" ford???
I've been looking to do a solid front axle swap on my F-250 93'. I found a dana 60 front high pinion and a dana 70 rear from an 87' both for $1500. Is a dana 70 stronger than my 10.25"? Or should I just spend the $1500 on a better or newer dana 60? Thanks.
Hope this helps. I found it on another website. It is a good write up.
Ford 8.8 Rear Axle Pros It's Under There Already VSS/ABS Models Cons 5 lug, 1/2 ton, Semi-Floater C-Clips Weak Carrier Bearing Caps Weak Housings Ford 9" Rear Axle Pros Common Tons of Aftermarket Parts Ground Clearance Full-Floater Conversions Indestructable (If You Have the Cash) Cons 5 lug, 1/2 Ton, Semi-Floater No VSS/ABS Low Pinion See "If You Have the Cash" Dana 60 Rear End Pros Some 35 spline Good Aftermarket Decent Ground Clearance Rare VSS Models Cons Some 16 Spline Most Non VSS/ABS 3/4 ton? 1 ton? Who the Hell Knows Dana 70 Rear End If you want a 1-ton axle, but don't need VSS, and loathe GM, this axle is for you. Pros Fairly Common Cheap Bulletproof In Stock Form Cons No Spool Poor Ground Clearance Non VSS/ABS Visteon Sterling 10.25 If you want a 1-ton axle, and you need VSS, this axle is for you. Pros VSS Compatable in '87+ (with speedo re-calc) 90% Bolt In Ford PN F4TZ-1177-C Fixes Pre-'94 Axle Seal Problem Cons Weak Pinion Threads Axle Seals Leak Some Limited Gear Ratios, No Spool Expensive Corporate 14 Bolt If you want a 1-ton axle, don't need VSS, and don't care about "brand loyalty", this axle is for you. Pros Dirt Cheap Bulletproof In Stock Form Cheap Detroits Can Shave Pumpkin Some Stock Detroits and 4.11 or 4.56s Gears Cons No VSS/ABS No Spools or ARB Some Semi-Float Versions Massive Pumpkin *gasp!* It's GM |
