460 hp/torque specs-1990
Anybody know where i can get accurate horsepower and torque specs for a 1990 460 in an f-250, e4od, 4:10's?
Specs for your truck according to Chilton's 1987-96 repair manual.
1990 7.5l Hp 230@3600 Tq 390@2200 Not that you would, but don't be disappointed with these number as compared to the newer engines. The ol' 460 makes all of its power pretty low in the rpm range. Daywalker 92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high |
Thanks daywalker, I'm thinking about installing a vortech supercharger on it. It has a fe-resh complete rebuild, new tranny, thorley tri-y headers, flowmaster 3" exhaust, 4:10's, and a k&n. I use it mainly for towing, and even though it runs great, more is better in the mountains of Idaho! This should get me to about 475 ft/lbs of torque.
Make sure you have forged pistons,
and a bulletproof bottom end before you BLOW it.?. |
I'm looking at the exact same truck combo. The 460 is a great motor, except it likes gas.
Daywalker,
Does you Chilton's Manual give the stock stats for my 95 F250 460 ZF? Thanks in advance. Perry |
245hp and 405ft/lbs of torque.
What is a ZF, and what did they do to it to increase the H.P. over my 1990?
The manual says for a 95 7.5l (460)
hp 245@4000 tq 400@2200 The manual also is not tranny specfic, maybe the manual gives you the extra 5 ft*lbs. Daywalker 92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high |
>did they do to it >to increase the H.P. over >my 1990? Its a 5 speed heavy duty manual tranny. I don't know what the changes in the 460 was over the years. Probably just tuning the computer. Daywalker 92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high |
Daywalker and Pastmaster,
Thanks to both of you for the reply, I've been wondering for a long time what those numbers are. I know what I'm dealing with at the wheels as I have the before and after numbers that Banks boasts for my Power Pack, but, I never knew what was developed at the engine. Again thanks. Perry |
> >Thanks to both of you for >the reply, I've been wondering >for a long time what >those numbers are. I know >what I'm dealing with at >the wheels as I have >the before and after numbers >that Banks boasts for my >Power Pack, but, I never >knew what was developed at >the engine. > >Again thanks. > >Perry If its not too much trouble I'd like to see those numbers. Just curious about driveline loss and so on. Thanks. Daywalker 92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high |
Daywalker,
I'm taking this from the Banks brochure all numbers are read at the drive wheels for a 95 F350 E4OD crew cab with a 355:1 diff. It does not specify dually or not. ............................ Stock truck............ PowerPack peak HP............... 178HP@3200rpm......... 228HP@3600rpm upshift point HP...... 126HP@4200rpm......... 194HP@4200rpm Peak Torque.......... 334ft/lb@1800rpm...... 385ft/lb@1800rpm downshift point TQ.. 312.9lb-ft@2600rpm.... 377.7lb-ft@2600rpm best gained TQ...... 212.8lb-ft@3800rpm.... 306.8lb-ft@3800rpm I don't know why the peak HP and TQ are made at a different rpm than the specs you quoted from Chilton's, but that is what Banks has put in their brochure. I hope it helps, Perry |
Headers and MPG for 460
I have a 1990 F-250 with the 460. Does anyone know if installing headers would help the HP's. Also one more question. Is there anything I can do to increase the MPG's.
THX in advance of advice, Paul |
