New to BioDiesel questions
I have been reading stuff on this site, which I see you guys refference a lot.
http://www.biodieselcommunity.org/gettingstarted/ I have a basic understanding on how BD is made. I know I should invest in a appleseed processor and I will soon but first, I am going to make a few batches using the 2 liter bottle method. Questions 1. How do you drain off the glycerin ?(out of the 2 liter bottle) I am thinking a siphon pump. 2. Instead of a 2 liter soda bottle is there a cheap container that I can buy with a bottom drain ? 3. How do you filter the WVO ? 4. I did not see anything about drying a small batch using the 2 Liter bottle method, any good drying ideas ? |
The instructions that I had said to put your thumb over the mouth of the bottle as you turned the bottle over very gently. I didn't care for that, so I siphoned using fuel line from radio-controlled aircraft. as far as filtering the WVO, I used a strainer. If I were to do that again I woud probably put a coffee filter inside the strainer. Didn't see anything on drying it, only washed it several times. Google "Dr. Pepper method".
Originally Posted by caverjoe
Not sure about your area but we get 5 gallon jugs with bottom drains from a pure water store.
http://www.homeandbeyond.com/prod-0173174.html Also at the grocery store I found a margarita mix bucket with a drain in the bottom. |
