Can a 7.3 IDI Turbo diesel run Bio Diesel
I own a 1994 IDI turbo diesel.
What needs to be done to run bio diesel on my truck. Just curious, Thanks, Chris |
There is nothing you need to do to run on BioDiesel.
But to run on SVO (straight vegetable oil) & WVO (waste vegetable oil) there are some things that you should do. Although, the IDI engine is very tolerant. |
ive been running straight used veggy oil in my rear tank for the last two years. works great and smells even better. i make a point to put a little diesel clean in there every onces and a while though. cheep insurance!
f 350
can i run biodissel in my f 350 7.3 1997
Yes! You can run Biodiesel in your truck with no mods.
So I can just pump biodiesel into my tank and just run it like that no tank mods or a
nthing |
Or change any hoses
You don't have to do a thing. Just make sure you change your fuel filter more often at first. Biodiesel will take all the crud out of your fuel system. All hoses are compatable after 1994.
Thanks for the info
also can my dodge ram 2500 2003 5.9 24 vale use the biodiesel with no mod to or what do i need
No mods on that one either. Isn't biodiesel great!
