302 Starter hook up in my Ranger
Ok guys,
Here I am in the final steps of the 302 swap and here's yet another issue. The 302 is from an 88 F150 EFI (converted to carb) Allright the starter on my ranger had 3 hookups, one 12 guage from the solonoid, on 4 gauge positive from the battery, and one negative. The starter on the 302 has 1 place to hook up on the starter, why? I'm thinking it's a positive hook up, but I hook it up from where, and what guage? Logic tells me, I should use the wire from the solonoid(at the fender) but a 12 guage alone seems small for a starter. What about a ground? shouldn't I ground the starter, if so where? There's only the one hook up, unless I just hook up a ground on one of the mounting bolts, would that be a good idea? I need your help guys. Thanx, Madmike33 |
You should get a solenoid (the "relay" on the fenderwell) from whatever vehicle the 302 came out of.
Then run a large-gauge wire from the solenoid to the starter. The original starter has a solenoid ON the starter. The 302 starter does not. You need a heavy-duty solenoid for the fenderwell, run a heavy gauge wire from the battery to the solenoid, and then from the solenoid to the starter, and everything should be fine. |
Exactly. Go to any autopart store and ask for a fender mounted starter solenoid. If they are too dumb to know what that is, say a starter solenoid for an 88 Ranger. You will need to run the small wire, (red with blue stripe) to the solenoiod. Then you will need a battery cable to go from positive to the solenoid, then one from the solenoid to the starter. Your ground needs to go to both the frame and the engine.
Matt |
Thanx guys, sounds good. I still have the truck the 302 came out of its up north but only about 1 hours drive. I knew I should have grabbed that when I was tearing into it.
Thanx again guys. Madmike33 |
