swap...
swap...
'88 350 one ton van 300ci engine, came with auto tranny....
I need to know if it will swap into a.... '75 F100 pickup with stick shift.... and if the carb setup, mounts, accessories, headers, etc will swap... for that matter will the FI may be worth the effort??? this is a possible swap between two friends, one wrecked his van and the fellow with the p/u needs a good engine....so??? what are the troubles..???? thanks...GENE |
swap...
I'm not too sure about how easy it will fit....But anything can be done with a little craftsmanship and a torch!}>
Austin |
