squeak in reverse
when i back up i hear a squeak, sounds like something plastic is rubbing, i have checked the parking brake shoes and the ring around the front axle shafts i cant tell if anything is bad or broken, it only does it in reverse.
sorry its a 1999 f150 4x4 ext cab, 5.4 130,000 miles
Its probably dry ujoints
i had the same problem beat mt head against the wall trying to figure it out. try spraying some pb blast or wd40 all over the ujoint. it keeps it quiet till you can fix it. fixing it is another story. good luck
thank i will try that in the morning
Had the same thing and it was a bad U joint.
