rough starting 97 7.3 turbo
I have a 97 f250 with 7.3 turbo I have to plug it in to get it to start once it is running continues to run rough even after it has warmed-up.
UVC harness, IPR seals, Bad Injectors or bad ICP. Are you running stock? There are alot of things that can cause a rough idle
Started when temp. first got cold but has continued even on warmer days. Everything is still stock after problem started removed CC and muffler. Also anyone know if they make a manual just for the 97 f250 7.3 turbo without all the extras?
bought truck with 124k now it has 159k do not it done before but, I have not
Thank you for your help!!!!!!!!
Try some of these test and let you know |
This may help also....
Here is what is needed to put a gauge together thanks to Swamps site. If you don't have access to a scantool, then go to your local hydraulic supply house, and have them make you up a mechanical gauge. You might spend $60 or so on high pressure hose, fittings, and a quality 0-3500psi liquid filled gauge....but having this hose available for future diagnostics might be more valuable than you think. The hose which you will need will need to be about 40" long, rated for (minimum) 3000psi working pressure (12k psi burst rating!) with the gauge on one end, and a #6 female JIC swivel fitting crimped onto the other. You will also need an individual fitting to screw into the head to go from the head to the hose. This single fitting will be a 90degree fitting # 5 "male boss" (sometimes called # 5 o-ring) on one end of the 90, and a # 6 male JIC on the other end of the 90. Our local hydraulic shop would label such a fitting as 5MB-6MJ90 "JIC" is nothing special...it's just 'hydraulic talk' for a 37degree flare fitting...standard hydraulic stuff here...nothing rare by any stretch. Looking at the top of (either) cylinder head, you'll see the factory stainless braided oil lines (one to each head) then you'll see a few bronze colored plugs... (Engine off, of course) Using a 5/8" wrench, remove any one of the bronze plugs, and install the 90deg fitting into the hole. (save the plug for reinstallation , after testing). and the O-rings are reusable, unless brittle, cracked, etc... The single 90deg fitting will have a "jamb nut" on the O-ring side...screw the fitting into the head, "aiming" the 90 away from the turbo, intercooler pipes, etc...and then tighten the jamb nut, to "squish" the O-ring also locking the 90 from "spinning" around as you attach the swivel end of the hose to the 90. No sealants, loctite, or teflon tape are needed on "JIC" or O-ring fittings...and don't overtighten them...usually about 180degrees with a wrench past finger |
