unkown hose connection
i have a p0171 code and was looking under the hood and noticed the hose unconnected. this hose goes from coffee can to unknown connection. pitures are in my gallery if you want a better idea of the hose i am talking about.
any other info need please post , also vehicle in in my signature. |
also while engine is running this thing is sucking alot of air
The hose goes to your smog pump (air pump) that's probly also the sucking noise......
JR |
Originally Posted by flareside_thunder
The hose goes to your smog pump (air pump).
The hose is: D4ZZ-9D667-A .. Corrogated Flex Hose It runs from the charcoal cannister to a plastic nipple (held on by a clip) on the aircleaner that connects to the emission ventilation filter (E7TZ-9D695-A-Motorcraft FA-1047). Smog pump hoses are made from neoprene. The hose is available from Ford ~ Suggested list price: $19.80 FYI: "coffee can" is a slang term for a vacuum reservoir tank, not for a charcoal cannister. |
Sorry, number dummy you're right....I remember pulling it from there now.....
JR |
would you have diagram of this set up so i can see, all the diagrams i seen are not to clear in connections
I have that same hose and it just hangs there open. It comes off of that cylindrical thing in front of it. I think it some sort of filter for the smog pump.
http://i136.photobucket.com/albums/q...4/100_3701.jpg http://i136.photobucket.com/albums/q...4/100_3700.jpg http://i136.photobucket.com/albums/q...4/100_3699.jpg |
So am i to assume that this hose just hang down, and connects to nothing. seem very odd considering a amount of air this hose sucks. but in the additional pictures it looks that way.
thank for help from those that posted. i also seen the so called coffee can refered to several time here on FTE. i also seen that my truck does not have this can. i will research more on this 171 code. I also got P0174 today (bank 2) am i assuming wrong that i should not have a bank 2 on an inline 6 engine. |
I think Ford upgraded the "coffee can" to a plastic resevoir after 94 or 95. My 94 has the can.
regards rikard |
up date of situation
any other info need please post , also vehicle in in my signature. so now all is well. after some time trying to track down source. |
Thats great news! I know it took you a while, but you got it. Sometimes its hard to find out what the actual problem is. Congrats!
