Memory Seats
My power memory driver seat just started doing this: If the seat is reclined and I push the memory button - everthing returns to set position except the seat back - it comes half way up and stops. If I recline it all the way forward and hit the memory button, it will return to set position. Anyone else experienced this or have any ideas?
Hmm. No, but I did notice if you try to set the seat bottom all the way back, it stops and you have to hit the button again to get the last couple inches. Does your do this?
Yes, you are correct about the last two inches
I have the same thing..you loose the last 2 inches or so. I have not had the recline problem. I also noticed that the pedals in the floor have about half an inch left in them when going full forward after using the seat memory to do my adjusting for me.
I just purchased my 07 last week. I tried the reclining seats and hit the memory button as well. Like yours, it seems every thing but the recline went back to the preset position. The recline went half way up. I hit the switch to put the set back up and it did so. I then hit the memory and it went back into position. Sound like the same function.
yep, but it didn't used to do that.
