Diagnostic equipment for EEC-IV.......PICS
In a recent thread some folks did not seem to be aware of what is available to trouble shoot these rigs. The scanners out (generic and manufacturer specific) there don't do much for OBD-I since there is no "Data Link Connector." However, many of the functions that modern scanners (Snap-On Modis, MAC Mentor, manufacturer specific scaners) allow one to do on OBD-II rigs (and then some) can be done with the EEC-IV ODB-I rigs too. It's just a matter of knowing what is available and where to get it. Over the years I have accmulated a fair amount of EEC-IV specific test equipment, and I will share with you what it is and what it does
https://i163.photobucket.com/albums/...7dc04011-1.jpg The most usefull of the EEC-IV specific tools is the Monitor. It hooks up in series with the computer and the wiring harness. It has a built-in digital display (for volts, ohms, mSEC, hz, DEG...which ever you choose) that you can set where ever you want within a 5 feet range (roughly) which comes in handy for test drives. You can choose to display whatever you want...be it TPS, MAP, MAF, coolat temp sensor, fuel injector pulse width.....whatever. The big fat knob with the blue and pink around it is used to select what get displayed on the digital display. The Monitor also displays the firing of the injectors in real time, the spout (whether or not it is hooked up), the switching of the O2 sensor(s) in real time, the TAD and TAB and much more all with a series of LEDs. Each application calls for a different overlay. I use the 92 Mustang overlay since that is the computer that I have. If anyone here gets a Monitor but needs an overlay, I can likely hook you up. I have almost every overlay that was made. The Monitor also came with a couple thousand pages of text to troubleshoot, I have that too. This is just the tip of the iceberg regarding what the Monitor can do. https://i163.photobucket.com/albums/...7dc04005-1.jpg This is the Monitor Recorder. It allows you to record up to 8 channels of what the Monitor sees. You can record up to a certain amount of time (10 minutes I think, just push the START RECORD button) and when you are done you hit CAPTURE. You then playback the channels you recorded 1 or 2 at a time. The data either displayed on the digital readout, the analog readout (both are on the Recorder) or an external volt meter or scopemeter of your choice. It hooks up to the Monitor via PORT A and PORT B. https://i163.photobucket.com/albums/...7dc04015-1.jpg This is a fuel pressure gauge and a vacuum gauge...it can be used for either. The data that this reads can be inputed to the Monitor or displayed on a volt meter or scopemeter of your choice. https://i163.photobucket.com/albums/...7dc04013-1.jpg In many cases the Monitor (and breakout boxes) can be a pain to install due to space issues. This relocates everything and makes the hook up of the Monitor a cake walk. https://i163.photobucket.com/albums/...7dc04002-1.jpg This is used to alert the driver that a trouble code has been logged into the EEC-IV. It hooks up to the test connector. When a code gets logged, it beeps. It is usefull on test drives + it also beeps on continuous memory codes...the ones that don't light up the CEL. https://i163.photobucket.com/albums/...7dc04003-1.jpg A TFI bench tester....fairly straight foreward what it does. Plug it in, push the button. If it does not find a fault, both LEDs light up. Not the greatest, becuase it does not catch the problems that cme and go and it does not give much info. This is the best TFI ignition system diagnostic tool out there as far as I am aware. If hooks up in series with the TFI module and has a series of LEDs that tell you what is going on. I will also diagnose a no start condition. It has a little breakout box off to the side so that you can measure the signal going through any given wire associated with the system. It comes with a manual that tells you how to trouble shoot based on any given LED indicated fault. https://i163.photobucket.com/albums/...7dc04012-1.jpg This is a breakout box. Not quite as handy as the Monitor, but it does have it advantages. I like to use it in conjunction with a scope meter so that I can graph the data in relation to a given time frame. This is good because I can then catch things like a bad spot in a TPS (or any sensor for that matter) that any old volt meter or even the digital read out on the Monitor wont catch because it is not fast enough. A scope meter will catch ANYTHING. This is the OTC version. These allow you to probe any of the 60 pins that plug into the EEC-IV quickly and easily. https://i163.photobucket.com/albums/...7dc04010-1.jpg This is the Thexton breakout box. Different construction, but it does the same thing. https://i163.photobucket.com/albums/...7dc04014-1.jpg |
Wow, eco......goodluck with that....looks ummmmm confusing to say the least......please tell me you wing it with all that stuff.....then I wouldn't feel too much like a moeran......Later on
JR |
My Fluke scopemeter...
https://i163.photobucket.com/albums/...7dc04008-1.jpg This is a diagnostic cable so to speak that hooks up in series with various parts of the ignition system then plugs into a breakout box. This is nice because the whole ignition system is layed you right in front of you and it is easy to get reading. No more fussing around with back probing. https://i163.photobucket.com/albums/...7dc04016-1.jpg Volt meter and amp clamp.....fairly straight foreward. https://i163.photobucket.com/albums/...7dc04017-1.jpg This is my exhaust gas anayzer. Hands down the best way to know how a motor is running. It is non-intrusive and will tell you whatever you need to know.....if the motor is running rich, lean, missfire etc.etc. Everything gets displayed on a laptop and it runs on OTC Microgas software. https://i163.photobucket.com/albums/...7dc04007-1.jpg This is a smoke machine. It finds leaks of all kinds...mainly used for vacuum leaks and evap leaks....but for these rigs not so much on the evap system. It also works for finding oil leaks in newly assembled things like rear ends, manual steering boxes etc. https://i163.photobucket.com/albums/...7dc04006-1.jpg |
Damn dude... I'm at a loss for words. Haha. Wanna come out to CA and test my truck for me? All that stuff looks really complicated...
Originally Posted by eco
.... Funny thing is, this stuff can be had for very cheap. On top of that, half the time when I run into this stuff it looks like it was sent to the dealership service depatment, set in a corner and never touched (the Rotunda stuff that is)........
....For some reason those dealer techs did not bother using this stuff. :rolleyes: .....The Rotunda stuff costed me anywhere from 10 dollars to 150 dollers per item. HeyZeus H. Crispus!... That's close to 10 to 20K in original equipment cost for all that Rotunda stuff! Where the hell do you shop????? 2 break out boxes this guy has... 2! :-huh |
Yes, where do you shop? I'd love to have a BOB and a lot of that other stuff -- and for OBDii stuff as well.
ford2go |
Damn eco, you're set to diagnose any ford OBD-I system.
Now I feel sheepish for using and Actron scanner and a Fluke multimeter......:-X15 |
the majority of what I got was still in the factory packaging....unopened.
WHOA!!!!! good finds..no GREAT FINDS! i should have gone down to the dealership that just got bought out and shut down!! i could have nabbed some of that stuff:-banghead
Eco, I'm buying a used Monitor and I'm not sure if the manual is included / available. Have you scanned your Monitor manual into pdf format? I would be interested in obtaining a copy. Thanks. Old Ford Instructor
Sure Proof Test for TFI ?
Eco and friends!
I've done a lot of reading the last couple days on the TFI failures in the older model Fords. I have an 1988 E-150 conversion van in very good condition except for this stalling out, no start problem. It looks like there was a major issue and a major lawsuit that Ford settled out of court around 2001. A known issue involving random TFI failures due to overheating of the unit. I read some people's experiences about replacing a brand new TFI module that tested good with another brand new one and it corrected the no-start problem. Conclusion: The standard tests from before cannot always detect a bad TFI. A TFI replacement story: https://www.ford-trucks.com/forums/9...stributor.html Suggested Testing Procedures that reportedly don't always show a bad TFI: Ford Ranger/Bronco II TFI Ignition Diagnostics I am wondering two things. 1) Does the Ford Rotunda TFI tester give a more accurate test than anything else? From the article number (87-21-10) issued by Ford it looks like it might have come out in 2010? If so, where in the world can I get one reasonably? I haven't been able to locate anything yet on eBay or by searching for Ford dealer out-of-busines auctions. 2) Motocraft TFI's are quite expensive. I can get one at near wholesale for between $100 and $150 plus shipping. What aftermarket brand is the next best option in your opinion? Thanks! Here is Ford's published article on the new test procedure: EEC IV - TFI MODULE AND PIP SENSOR - Article No. 87-21-10 NEW DIAGNOSTIC PROCEDURE LINCOLN-MERCURY: 1983 MARK VI 1983-86 CAPRI 1983-87 LYNX 1983-88 COUGAR, MERCURY, CONTINENTAL, LINCOLN TOWN CAR 1984-88 TOPAZ, MARK VII 1986-88 SABLE MERKUR: 1985-88 XR4Ti 1988 SCORPIO LIGHT TRUCK: 1983-88 ALL LIGHT TRUCK LINES ISSUE: A new diagnostic procedure for testing the TFI module and PIP sensor has been developed. This new procedure allows the technician to take a direct path when testing the TFI module and PIP sensor with the use of the new TFI IV diagnostic tester (Rotunda No. 105-00003). ACTION: If service is required, use the diagnostic procedures on pages 29 through 60 of this TSB. Insert these pages in the Engine/Emission Diagnosis Manual, Volume H, Section 15. OTHER APPLICABLE ARTICLES: None WARRANTY STATUS: "INFORMATION ONLY |
If I had that kinda money. Don't you think I'd be sportn a brand new rig. Who do you work for? Sale rep?
