Ford Truck Enthusiasts Forums
-   Explorer, Sport Trac, Mountaineer & Aviator (https://www.ford-trucks.com/forums/forum32/)
-   -   91 Explorer PCM Location? (https://www.ford-trucks.com/forums/650924-91-explorer-pcm-location.html)
swj123 09-09-2007 09:58 AM
Can someone please tell we where the PCM is located in the car? Thanks
Backin72 09-09-2007 10:03 AM
Remove the kick panel on the front passenger side, should be right there.
swj123 09-09-2007 07:59 PM
Does anybody know where I could get a replacement reasonable? Thanks
Backin72 09-10-2007 11:12 AM
I'm guessing you located your PCM? Try ebay. Search using PCM and ECM, will be listed under either. There is a code on your PCM. Call your dealer and find out which numbers/letters have to match up when purchasing a new/used one.
swj123 09-10-2007 11:15 AM
Thanks, I did locate the PCM. I will look on ebay for one. Thanks, Mike
marragtop 09-11-2007 03:03 PM
Are you sure the PCM is bad?
quicklook2 09-11-2007 03:28 PM
another post said it was not.
rarely the computer goes bad.
swj123 09-11-2007 03:36 PM
It turned out to be two wires at the EDIS plug that were chewed by mice. The computer is good. Funny, I just seen one on ebay for $35 with my exact numbers. Thanks to all that replied.
