square tubing tip
removing the weld seam in square tubing
some of you might be like me and like to fabricate stuff... when making telescoping parts from square tubing you have to deal with the inside weld seam on the larger tube... found this on another forum and it works better than trying to hog it out with a file or rotary burr. john |
Attaching fittings to Nylon fuel line
I heard nightmare stories about attaching fittings to nylon pipe. After search the web for the correct tool I drew the line at spending $100 plus for a tool I may only use 4 or 5 times. I installed the pipe so I could get the correct length measurement. Then took the pipe back out. I keep calling the nylon fuel line pipe because it's measured like pipe (uses OD unlike hose that uses ID)
Then I came up with this. Just used a pipe flaring tool & my bench press. If you don't have a bench press you might be able to use a vice. https://cimg3.ibsrv.net/gimg/www.for...65c4a37894.jpg Pipe flaring tool and bench press https://cimg6.ibsrv.net/gimg/www.for...8ccf8ae6f7.jpg Attach the flaring tool just below where the fitting will end up after you're done https://cimg7.ibsrv.net/gimg/www.for...80a838e6ab.jpg Press the nylon pipe all the way to the fittings shoulder https://cimg8.ibsrv.net/gimg/www.for...1fdfa1fe98.jpg Complete Just like the big boys Easy Peasy. Now install and clamp it to the frame. No more rusted fuel line. |
We all know we should wear safety glasses when grinding or cutting metal.
Following Murphy's law the pair you can find is always cloudy and hard to see through and new ones seemed very expensive. I went to e-bay and found where you could buy safety glasses for .99 each. I ordered 10 pairs. So for just a little over the cost of one pair at Home Depot I have 10 and always have a clear pair to use and do not feel guilty throwing A cloudy pair away.:-X22 |
New to this site and restoration, fell into a '50 F-1 through a friend and decided to restore it.
Is this the right section to ask and get answers to questions or do I have to go to a different section of the site? As you can possibly tell I am not all that computer literate. |
YOU'RE IN THE RIGHT VICINITY
Originally Posted by ynot321AB1
(Post 17747747)
Is this the right section to ask and get answers to questions or do I have to go to a different section of the site? As you can possibly tell I am not all that computer literate. I'm just finishing up my 1955 F350 and the guys on here can really help you out. I signed up when I first started restoring the F350 and they have all helped me out a lot. Good luck! |
(Post 17747747)
Originally Posted by mgerdau
(Post 17747806)
l, welcome aboard, ynot321AB1. You've posted in the Cool Tips and Tricks. It does take a little bit of maneuvering on the site. But posting in 1948-1956 F1,F100 & Larger F-Series Trucks is were all of the juicy stuff is.
I'm just finishing up my 1955 F350 and the guys on here can really help you out. I signed up when I first started restoring the F350 and they have all helped me out a lot. Good luck! By the way, I am getting better with this computer as I have only threatened it wtih a hammer 3 times today. |
Let me add my welcome to FTE the best Ford Truck Forum on the world wide Web!
What you should do is start a new thread and introduce yourself and show us pictures of your truck. Just above the header above this thread you'll see a blue button that says New Thread. Click on it to start your introductory thread. |
ynot, Let me add my welcome to FTE also. Where are you at in Arkansas? I'm in the north central part of the state.
Mark |
https://cimg9.ibsrv.net/gimg/www.for...0eacb9adab.jpgOne way to hang your doors when you have no help.
(Post 17747806)
Well, welcome aboard, ynot321AB1. You've posted in the Cool Tips and Tricks. It does take a little bit of maneuvering on the site. But posting in 1948-1956 F1,F100 & Larger F-Series Trucks is were all of the juicy stuff is.
Here is the link https://www.ford-trucks.com/forums/forum41/
You can get to the various forms from the black menu bar at the top of the page. https://cimg1.ibsrv.net/gimg/www.for...2167d25def.jpg |
My Project and a what is it question
Originally Posted by petemcl
(Post 17747889)
Welcome. You are in the right place. Ask any question that you wish but you need to learn how to post pictures. That is important if you want good answers.
the item was attached to the sensing unit of the gas tank at the connection of the wire leading from the unit to the gas gadge, is this a grounding item or what is the purpose?https://cimg1.ibsrv.net/gimg/www.for...260aaa8311.jpg1950 F-1 1/2 ton https://cimg0.ibsrv.net/gimg/www.for...41afac7755.jpgWhat is the purpose of this item? It was attached to the sensing unit of the gas tank, is this a grounding unit or what? |
