Leaf springs
I bought 37-12.5 for my truck and i need at least a 4" leaf lift does anyone know any cheap places i can buy leaf springs... and will the rear end clear thoes tires and will a 4'' in the front clear? 1997 Powerstroke F350 let me know
yes there is a 4" lift out there from tuff country i think.
not sure if it will clear or not might have to shim the bumper a little. right now on stock height i am clearing 33's with no problem. the back end will clear no problem. |
You may be able to do the reverse shackle on the front & a block on the rear,I run 31's with tons of room..Although. PO shaved the front bumper a bit & my tires rub on the springs in real tight turns ,,
Others will have more ideas... |
what kind of truck do you have? 37's are alot of tire for a 4 inch even on a 350, i would go with a 6 inch on a 350 and you would fit with little or no bumper mods, but thaat would really fill the truck wheel wells up, on a 250 it could go with a 6 inch but would not like going offroad, i run a 6 inch on 35's right now and that is the perfect combo, i could put 37's on it now but the bumper would have to go forward a good bit and i gurantee they would hit really bad if i twisted it up bad
