Elect. Ignition on 87
OK- i've heard enough.
i wanna change my old points to E.I., just need some info on who ya'll trust. Mallory, MSD, etc... i am hopin for a distributor based system. gimme the pro's n con's of what you think Great Gearheads O the Net!!!!! |
two minutes and nothin- DANG!!
BUMP - For the non-stock gearheads....
i wanna change my old points to E.I., just need some info on who ya'll trust. Mallory, MSD, etc... i am hopin for a distributor based system. gimme the pro's n con's of what you think Great Gearheads O the Net!!!!! http://www.performancedistributors.c...istributor.htm Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at: https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html |
i have checked out the site a few dozen times and like what i see.
got the order form saved, many thanks! |
decided what you gonna do yet?
gonna do it- but i have an overheatin prob to fix first.
on the honeydo end- if i can get my new driveway i will hold out for that first. more $ but it has become a major safety factor , if you been here ya know.... While on projects- still lookin for a decent 460- that is somethin i can put a lil bit o' $ in on from time to time. the smaller stuff seems to get done here quicker than the big jobs. long as somethin gets done... |
Hard to beat the MSD system but if funds are close the old Dura Spark with MSD 6A works great also
omit duraspark box |
for $65 i changed the points out in my bronco to electronic with built in rev limiter! bought it at summit (which is a short drive for me) and highly recommend it! best part is it uses stock parts so any and every junkyard has oodles of spares!
http://store.summitracing.com/partde...5&autoview=sku -cutts- |
thanks!
it's on the list, and it will get done. It will have to wait on my latest headache though.. The actual ignition switch has gone crazy on me - like the rollers are so wore out it wont lock into the "on" position. Freaked me out goin down to take the ol lady to work- she just shut down. After startin and stoppin three times i figured out what it was. No just sittin at idle it will vibrate to off. just another brick in the wall..... |
Seems like when it rains it pours. I need to replace the switch on my 82 if I ever get the tranny working right.
i still like the mallory unilite system i had in my old motor. will use it from now on if i have a choice for a singe self contained unit. it doesnt require a seporate ignition box. all you need is the dist and a coil, 3 wire hook up
My Mustang has a Mallory Unilite w/ Ford Motorsport coil and a MSD 6A control box. I know it's a good system but I'm chasing a gremlin in it right now. It's cut off several times going down the road.
Box was in the car when I bought it. I think I've got it fixed, hasn't done since last Thursday anyway. Whoever put the control box in grounded it to the battery. I moved the ground to the inner fender.
