Most advanced water injection available!!
We've received several questions about our systems here on FTE. I thought it would help others with similar questions if I posted some info from our website. So here it is :) No supercharger or turbocharger system is complete without a water methanol/alcohol injection system. Whether or not you are running an intercooled system, the benefits gained from water injection are so profound you simply can't afford to run without it. The best part is that these benefits can be realized in less than an hour... the time it takes to install our system. Water Alcohol/Methanol Injection Will Reduce Your Air Charge Temps and Provide the Following Benefits:
Our trunk mount kits make it easier than ever before to install. Unlike other systems, you won't have to worry about assembling the components first and then trying to find space to install the pump, container, hoses and wiring under the hood of your ride (nearly impossible on newer vehicles). This can be time consuming (between 4-6 hours) and costly (mechanics can charge $100+ per hour). Our trunk mount systems are typically installed in less than an hour!! That's because our system comes pre-assembled. So the only thing you'll have to do is install the tank assembly, injection nozzle, and the fluid lines connecting the two. You WON"T need to remove your bumper or fabricate mounts in your fenders!! We even provide you with REAL installation instructions, not some generic steps that were haphazardly put together. Compare our trunk mount systems to the competitors systems and you'll quickly see the difference! Our Kit vs. Leading Competitors:
Have questions or need help choosing the right water methanol/alcohol injection system for your application. Gives us a call toll free for immediate service at 1-801.447.ALKY (2559) http://www.alcoholinjectionsystems.c...ted_stage2.gif Stage 1 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System Stage 2 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System |
Do you have any customers running this system with Roushchargers on 5.4L V8s? :-D
We have customers with roots style superchargers that have installed our system. These superchargers are a great application for water injection because of the high air charge temps they produce. Let me know if you have any questions about our system. - Nathan |
