2002 diesel cutting out
my 02 diesel was cutting out and the check engine light would come on and stay on. turn off the truck and turn it back on and the light goes out. I thought maybe it needed to warm up but this does not seem to be the case because it happpened again after driving for awhile. it also occasionally hesistates while driving. I've been changing the fuel filter every 15,000 miles and draining the fuel bowl every oil change. the truck has only 72,000 miles. any thoughts on this matter.
Quick guess would be CPS. They either go quick or give you alot of warnings. I would get a CPS replacement, about $28 and replace it. The only probs I've had with my 02 is the pedals and several CPS failures. CPS takes you about 10 mins to replace.
I second the CPS, but it took me 20 minutes to find it the first time (trying to get the location over the phone) and 2 minutes to change it. Check here for instructions: http://guzzle.rbmicro.com/cps.html
Sounds like the cps
Nick |
Let us know what you find ....Cisar
Bought 2 from dealer the other day, one apare for me and one for someone on the road that may need it. 27.00 each.
