Ford Truck Enthusiasts Forums
-   1999 - 2003 7.3L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum31/)
-   -   britebox flc (https://www.ford-trucks.com/forums/642427-britebox-flc.html)
stroken 08-14-2007 11:29 PM
britebox flc
Im looking at the britebox flc which allows highbeams low beams and foglights on all at the same time but i don;t know...in my 2003 f 350 what is a sealed beam headlight, or replaceable bulb, im guessing replaceable bulb but not positive, and in the chart it shows f-series and lists options and super duty and lists options..which one do I follor, both have different numbers....superduty? http://www.dieselsite.com/index.asp?...ROD&ProdID=358
yamaguy 08-15-2007 12:12 AM
The XL trucks have the sealed beam lights. All others have the replacement bulbs. I like the idea let us know how they work when you get it.
rebelchevy02 08-15-2007 12:15 AM
Heres a sealed beam
https://www.ford-trucks.com/forums/a...tid=5390&stc=1
Heres a replaceable bulb type
https://www.ford-trucks.com/forums/a...tid=5392&stc=1
Now the skinny, I would not recoment using both elements on either light sets. High beam + fog is ok, Low beam + fog is ok. High beam + low beam = decreased bulb life. As both elements are in one bulb. For both styles. One just replaces bulbs, the other replaces the whole bulb/reflector. High + low beams on at the same time is for 4 head light systems IMO
Oh and thank you pclark76 for the images :-wink
