Anyone changed all injectors on a 2.5L?
Hi can anyone tell me what other parts i would need when replacing the fuel injectors on my 98 ranger 2.5L. I know 4 injectors, I guess the fuel pressure regulator since it is out. what gaskets? ECT...
What makes you think the injectors are shot?
I have 235k miles on my 87 2.9 & have'nt touched the injectors. Sold my 95 Taurus with 150K miles & never had an injector problem on it either. |
I have intermittant missfireing when i plug in the scanner it says (detected #2 cyl misfire) the whole engine shakes i loose power then i continue driving and it clears up5 minutes later it happens all over again. i replaced the plugs,wires,both coil packs and reseated and checked all connectors under the hood.
In that case, maybe it is a bad injector.
I dont have a shop manual for a 98, but the only thing mentioned in the shop manual for my 87 2.3 is replacing the injector O rings if needed. Some highlights on the 87 Open fuel tank cap & release fuel pressure at the schrader valve. Remove 2 fuel supply manifold retaining bolts Carefully disengage manifold & injectors from engine and remove manifold & injectors Grasp injector & pull up while gently rocking injector from side to side. Inspect injector O rings (2 per injector) replace as needed. Instalation of new injectors: Lubricate injector O-rings with light grade oil Install injector into fuel supply manifold. Use a light twisting, pushing motion to install them. Dont know if that will help on your 2.5, but thats how it's done on an 87 2.3 liter. Good luck with it. |
Thanks for the info but my truck is way different i think i have to take off the air chamber (tunnel) because the fuel rail is under that.
Well that does'nt surprise me.
BTW, heres the pinpoint tests that I show for P-0302. Check for intake vacuum leak. Check compression Ignition circuit malfunction bad spark plug injector circuit malfunction Faulty injector Hope this helps |
Thanks i found the problem this morning. on the way to work today the problem happened again so i pulled over and started to pull each plug wire off and when i pulled off #2 cyl there was no change but i had a great spark. i shut off the truck checked the plugs on that cylender and they look like new (Because they are) i started it again the engine was still shacking i reached under and started unpluging the fuel injectors one at a time every one made the engine stumble even worse except #2 cyl. i shut off the motor and i checked across the 2 electrical pins on the #2 injector with my multi meter and had Zero Ohms, wide open. when i check the others i have 4.7 ohms. so i have to say that is it.
Nice job with the troubleshooting & it looks like you're right, the miserable thing is going open.
Glad you found the problem & good luck with the swap. |
Ok i finnished it, the truck runs great again. yup i had to remove the air chamber or tunnel or plenmium what ever it is called once that was done i removed the injector plugs and 2 bolts that hold down the fuel rail and out they came. all in all the whole job took about 1 hour the hardest part was finding an auto parts store that had them. i went to Pepboys they do not stock them, AID auto they do not stock them, Auto barn seme thing. struss stores no good. NAPA not in stock. Finally i looked on line at AutoZone and they tell you if they stock them and did but only 1 so i had to drive to 4 AutoZones to buy all 4 but i got them and job done.
THANKS 87 XLT for all your help. |
And thank you for the interesting blow by blow on how the swap is done. Looks like the hardest part is finding the injectors.
Glad you're up & running good again. |
It is really long long ago...
But could anyone tell me that if the fuel injector 0432193835 can be fitted for ford ranger 2.8 d?? Usually it is for FORD Ranger 2.5 D, if can not, which injector is the correct one? Thanks!!! |
