Axle Flip on the 60 Rat Rod
Some of you have asked how the axle flip is going, so here are some pics. The C notch kit is going in next.
https://www.ford-trucks.com/user_gal...id=157768&.jpg https://www.ford-trucks.com/user_gal...id=157752&.jpg |
I Like it. Did you make or purchase the plates for boxing and "C" channel ?
That's gonna be one loooooow truck. I don't know if I like the angle cuts on the frame, but I'd be willing to bet you won't be putting anything in the bed, so that's not much of a concern.
With the rear mounted cell on my truck, it rides just low enough so that it doesn't look like a slant-nose 911, but it's not a body scraper. |
Looks like its going well nice work....
Quick question I am a rookie welder but can make a good beed not pretty but good with a flux wire mig welder would you use a flux wire to weld in the c-notch and box the frame? I have the same kit you have to flip the axle.
Yeah I did buy the c notch kit The progress is posted in my gallery. Also my nephew just asked me the same question on the welding. My answer to him and everyone else is if you can afford to buy the argon CO2 mix I think it yields slightly better results. Thanks everyone.
The argon mix is the way to go, I used the flux core when my tank ran empty and I filled the tank the next day without thinking twice.
so here is the c-notch and box plate welded in all thats left is to clean things up, and put it back together
https://www.ford-trucks.com/user_gal...id=158458&.jpg |
Looks good. Keep up the nice work!
Later, Bill |
getting closer to completion
https://www.ford-trucks.com/user_gal...id=163422&.jpg |
very nice, still could go lower, but i guess you want to drive it
Nice! I plan to use your gallery to help guide me thru lowering my rear. Thanks for posting those. Are those the stock rear leaf springs with some leafs removed or is that leaf springs from some other vehicle.
Thanks, rustfarmer |
Thanks for the pics they are worth a 1000 words!
Yes rustfarmer, they are stock springs just removed a bunch. Click on my gallery and you'll see the step by step of this project.
Thanks Dan |
Looks beautiful, rat...you probably already thought of this, but some have noted that the frame isn't what hits first, it's the center "pumpkin" on the bed boards. Are you going with a stock type bed? May have to make a hump or something...
