Silverstar Headlights - YES!!
After climbing out of the vehicle a few times at night to be sure the headlights WERE actually on, I gave up and got some Silverstar H13 ST2's from Advance Auto ($38.00/pr). WOW!! What a difference. Next I'll install some 9145 Silvers in the fog lights and I'll be set.
My '03 had SS's in both high and low beams, and, after driving my '07 at night I couldn't believe the difference. I've heard that the SS's have a reputation for needing replacement every year or so (the last ones I had didn't, maybe the guys who mentioned that drive only at night, or, drive with their lights on all the time), but, even if that's true, who cares? Being able to see is rather more important, I'd say. :) BTW - Put some H13's in the wife's Freestyle too. She's most impressed. I can't understand why Ford doesn't do a better job with the lighting. I mean, even the "lower end" Expy's cost nearly $40G - you'd think we'd get some decent lights, y'know? |
That would be nice if Ford would want to consider it.
It's kinda of sad when you can better lighting options in different suv's other then Ford. At the very least they could offer a lighting package. I for one would be more then happy to opt for it. |
what do you think about the lights that are for sale in the group buy? Real HID for $216 high and lows. H13 High and low Bosch HID kit.
My '03 had SS's in both high and low beams, and, after driving my '07 at night I couldn't believe the difference. I've heard that the SS's have a reputation for needing replacement every year or so (the last ones I had didn't, maybe the guys who mentioned that drive only at night, or, drive with their lights on all the time), but, even if that's true, who cares? Being able to see is rather more important, I'd say. :) BTW - Put some H13's in the wife's Freestyle too. She's most impressed. I can't understand why Ford doesn't do a better job with the lighting. I mean, even the "lower end" Expy's cost nearly $40G - you'd think we'd get some decent lights, y'know? Thanks for posting the info on the SS's. I went out today and purchased them for myself as well.:-X22 |
Must be a hot commidity, both places I went at lunch were sold out. Will have to try two more after work.
I put SS in my 06 F150 screw xlt 4x4 and I don't see any change from stock. Those cheap (under a grand) HID kits are illegal. Unless you replace the entire headlight assembly to one made for HID lighting.
To explain it simply as I can. A real HID(like on high end SUVs and cars) bulb produces light differently than incandecent bulbs. You need a projector type housing with a lens made for HID and not the reflector stye like the incandecent uses. The color and light intensity of HIDs are different and if not in the proper hosing will create a glare for oncoming drivers because the light from HID bulbs is not intended to be reflected out onto the road. If you research it some you will get a better more detailed explanation. I would hate to see someone spend the money on one of those kits and then find out they are federally ilegal.
Mark |
Were HID's even around in 1997?
The first production vehicle to contain both a high and a low-pressure gas discharge lighting system was the 1997 Lincoln Mark VIII
The 1996 Mark VIII was the first car to have DC (direct current) HIDs in the US. I am guessing many improvements have been made since then. I would not consider the first attempt as a good comparision for today's market 11 years later.
I found the link to the complete article explaining HID light. the article makes sense, HID light is produced differently and is treated different by the housing and lenses on the vehicles they come stock on. Check out the end of the HID section on this link, http://en.wikipedia.org/wiki/Headlight Here is the link on HID light i found it http://www.danielsternlighting.com/t...nversions.html |
I have a 1997 Lincon Mark VIII and it has HID's. My fathers 1996 doesn't. They put the HID's in the Gen 2 cars which were from 1997-1998. Wikipedia might have meant that they started putting them in the cars in 1996 as a 1997 model.
Mark |
