Low Side A/C connection 00 Expy
Where is it? I've searched every where, it's not on the compressor, nor the evap cannister or any line that I can see, even checked the rear A/C. I have some R-134 I wanna put in it as it's not cooling like it used too.. Any ideas?? I found the Hi side cap and plug but no low???????????
Thanks |
Hi, I have a '98 Expedition.....I would think the 2000 would be the same.
The High side is easy to locate.....just to the right of the battery. The low side is very near the fire wall on the passenger side. Pop off the black plastic cover over some electrical components that are attached the firewall. (You press underneath the cover to pop if off) Then look on the silver colored canister underneath those componetns and you will see the port sticking out. You will see the black cap. Hope that helps! Like I said ......that's for my '98. |
the low side is on the line by the battey above the valve cover.
shinew, you were right on the money, once that power module was out of the way there it was!! 2 cans later and I'm showing 37 degree's at the vent and she's cooling like she was new!! Thanks again!
Slick! |
