Explorer 2000 V8 oil pressure sensor location.
Hallo to all of you!
This is my first post, and allready have a question: where is the oil pressure switch located on 2000 Explorer v8 5.0. Like many other members, I'm heaving problems with oil dummy gaugue. Iwas trying to find it, but don't see it. Just wanna replace it with the new one ($12 Advance Auto). Thank you for any help. |
here is what i found on autozone's web site for a 99, should be the same on a 2000
*5.0L engines-Left-hand front of the engine, below the rocker arm cover |
Thank you, looks like I;ll have to take the power stering pump out in order to gain the acces (at least).
Once again thanks for your time. |
Just a quick F/U for all people reading this.
All you have to do in order to gain the access to it is to remove the front left wheel (driver side). Than take off the rubber shield held by plastick bolts and you'll se IT. Can't be any easier. Thanks for your time. |
