98 f150
having problems with my 4wheel drive not disengaging,any ideas thanks
Did you post this in the 1997 - 2003 F150 forum? I would think you would get a quicker response there.
If I remember correctly your system have a switch on the dash which can cause problems with engaging/disengaging same thing with the front disconnect unit. How those work and how you troubleshoot them I am not aware of. Hopefully someone else will come along and can shed more light on your issue than I can. Good luck to you!! |
thanks for the info,mine has the shifter on floor im going to crawl under to check out
Let us know what you find out and good luck with it!! |
try backing up a short distance. sometimes that may disengage it
thanks for all the ideas, think i figure it out. there is a round sleeve with a arm that goes in and out think its sticking.thanks for answering my post
Let us know if you get it fixed or need additional help. Good luck!!
thanks.ill see if i can get to it this weekend
just wanted to let you know what I found out about my 4x4 problem was. It is a electric solenoid that isnt disengaging,located up front
times like this i'm glad i've got an older truck. not all those gizmo's that would drive me psycho
