It's a lot easier to cut just below the top nut with a sawzall or a die grinder. I replaced mine with KYB Monomax (great improvement over the stock Ranchos).
Originally Posted by khadma
(Post 12709922)
I bet I can beat anybody in rear shock replacement.
Holes in the bed over the top nuts makes the job a cake walk. I need to replace shocks during this week along with brake pads and front anti sway bar bushings from Energy Suspension. (Mickey Mouse smiley here) |
Originally Posted by 2Fords1Jeep
(Post 12710459)
How many miles on the KYBs? It's good to get input on all The different shocks available, sometimes the more expensive Shocks are not the best. Yet, shock performance is subjective. |
(Post 12710481)
On my rear window. Thanks. |
KYB Monomax, the only way to go. I've had mine on for 8 yrs. (F150 4x4) and they still work perfectly, what a great ride and handling to. Ranchos suck, replaced two sets of them and called it quits, junk!
Originally Posted by BFTUFF
(Post 12715707)
I would like to try adjustable shocks on a truck, but discovering that they were bad would not be a good thing. It is amazing how expensive shocks can be, the last two used Explorers we bought still had the OEM shocks installed. |
(Post 12717175)
Which Ranchos? RS 5000s?
KYB Monomax: Not worth the price
I have been running the KYB Monomax shocks since last Spring (2012), and I really don't like them. They are only marginally better than the stock units at low to moderate speeds where the truck feels a bit tighter over small road bumps, but about the same as OEM at higher speeds. They are decent on bad fire roads, and jeep trails.
However, they did nothing to improve the ride/handling over road undulations. I get repeated side to side sway in sharp turns on roads with uneven surfaces, and worse, I get front end float on straight roads when I hit undulations, especially when towing (even light and well balanced loads), almost scary at highway speeds. The OEM shocks were about the same at the end of their life. The upside? I like the red color and how they look under the truck... Normally, I run Bilsteins or Koni, but I thought I'd try the Monomax shocks and I really wish I didn't. I have Bilsteins in my Porsche, F350, and had them in my Ranger, and they have matched my expectations in each case. That's my 2 cents.... |
IMHO an angle grinder with a metal cutting wheel is a basic tool for any DIY'er. I don't know how I got to the age of 50 without using one. It would have saved so much time and busted knuckles. :-arrgh
If you are not reusing an item, CUT IT OUT! |
Originally Posted by ewalt98
(Post 12722027)
(Post 12725143)
On my 98', they made an astonishing difference in ride quality and handling. Everyone who ride in the truck comments on how great it rides. No shock I've ever owned has lasted anywhere near this long. I love them and recommend them to others all the time with great return info.
Originally Posted by artfd
(Post 12722137)
If you are not reusing an item, CUT IT OUT! Blade, but this idea might be too MICKEY MOUSE for some people. I have resorted to removing 14 year old rusted OEM shocks of an Explorer With a Tigersaw. The Tigersaw could actually fit into places a grinder could Not fit. I have new Bilsteins ready to be installed on my F150, I will let you guys Know my impressions after a couple of days with the new shocks. |
My brother went through 3 sets of Bilsteins in short order, just regular town and hwy. driving. They all bleed oil. No thanks.
anyone?!............................http://www.healthdu.com/7.jpghttp://www.healthdu.com/8.jpghttp://www.healthdu.com/9.jpghttp://www.healthdu.com/1.jpg
(Post 12729111)
I was going to suggest using a reciprocating saw with a new steel cutting
Blade, but this idea might be too MICKEY MOUSE for some people. I have resorted to removing 14 year old rusted OEM shocks of an Explorer With a Tigersaw. The Tigersaw could actually fit into places a grinder could Not fit. I have new Bilsteins ready to be installed on my F150, I will let you guys Know my impressions after a couple of days with the new shocks. The KYB's were a great change for my truck. Ride and handling is 100% better than the stock Ranchos. |
