body side inner seal
I'm looking for a source for a body side inner seal, Ford part #247A50-1. This seal is mounted (on a crewcab)to the front of rear door (near the window glass) and seals against the rear of the front door (near the window glass). When the doors are closed, you just see a thin black seal about 1/4" wide running between the upper part of the doors. It is a plastic/rubber seal that looks like it is pop riveted with plastic rivets or plugs. Any ideas?
This is the cheapest I could find it for when my neighbor needed it. Hopefully this is the part you're looking for:
http://www.trademotion.com/partlocat...99&catalogid=2 Austin |
That may be the part, but the drawings? I think they brought some 7 year olds and had them draw the pictures...I'll call them tomorrow...Thanks kindly.
