adjusting transmission bands
I need to know how to adjust the second gear band in my 1994 ford explorer which has an A4LD auto tranny!
10' lbs, back off 2 turns.
do i screw it all the way in, torque to 10' lbs, and then back out 2 turns
yes, that is correct.
well thanks you very much. Im going to do that first thing in the morning. I did adjust the band somewhat and the second gear is still slipping a little but if i screw it all the way in then out 2 turns that should stop that.
It must be torqued to 10'lbs, then backed off from there.
I went and did exactly what u said but now the second gear is not working at all, should i screw it out some more or screw it in?
Leave it well enough alone.
There is obviously a problem that needs to be corrected. |
yeah i think i might. I cant seem to screw that stud/adjuster bolt in far enough to get any torque on it. I would assume this means the second gear band is gone and needs to be repaired?
usually once a trans starts slipping it needs a new band and maybe other parts as well.
it is probably a combination of things worn out. sounds like new transmission time, sorry. |
I was wondering if the servo could be doing this weird problem??
" I cant seem to screw that stud/adjuster bolt in far enough to get any torque on it. I would assume this means the second gear band is gone and needs to be repaired "
If you are unable to screw the adjuster in far enough to get the correct torque the servo is not the problem. |
