ABS problem
Today going home my ABS started working while braking up to a stop sign on the pavement? Okay really wierd...so i did some testing and figured out that my ABS is pulsing the brakes only between 50-15 mph...if im going 60 and start to brake it works fine till i get to 50 and then starts to kick abs and pulse my brakes...does that till 15mph and then stops and brakes normal again...
WTF does this mean...no codes for it... |
Bump. .
What kind of ABS sytem do you have? 4WABS or RWABS?
4wabs.... .
I think the sensors might be dirty. The rear pumpkin sensor is the easiest so start with that one, the speed sensors in the front hubs are a little bit trickier, they require allen keys.
where do they come apart at... i think theres just one for the entire rear axle....isnt it in the center diff?
