Can I swap a XLT instrument cluster for a FX4 one?
I've search for over an hour and all I could find was swapping a Lariat instrument cluster to an XLT, STX, or XL and all of the problems that go along.
Well, I have a XLT but I want to switch to the FX4 instrument cluster. Is this possible? Other then getting the miles programmed, is there anything else I should be aware of? <O:p Will my P.A.T.S. work?....will the truck start? <O:p Will all of my XLT functions work?...i.e. A/C, dome light fade, door/key chime, 4x4, etc. I was told that they won't if you don't program my XLT cluster into the FX4 one....is this true?<O:p Thanks for the help. |
Anytime you change the cluster, even to put the same type cluster in, you have to have a Ford scan tool to do a Programmable Module Installation (PMI) with either the data retrieved from the original module or programmed with as built data only avaliable from a secure Ford website for technicians, PLUS you must either do a parameter reset and/or reprogram two keys.
Now there may be work arounds from the underground but that is what you are supposed to do. That is aside from needing the module set for correct odometer reading. |
I wish it was a easy thing to do, I would really like to have the FX4 gage on my XLT.
Now there may be work arounds from the underground but that is what you are supposed to do. That is aside from needing the module set for correct odometer reading. Not sure if a truck that came with no tach (XL)will accept a cluster with a tach (XLT, FX4 etc..), but a FX4 cluster will definately fit in an XLT. |
Originally Posted by Joe04F150
(Post 5667636)
I only agree with needing the dealer to reprogram the mileage b/c it will register whatever is showing on the gauges. Other than that the only thing you need to do when swapping the clusters is disconnect the battery and swap out. Everything else works just fine, no programing keys or sensors.
Not sure if a truck that came with no tach (XL)will accept a cluster with a tach (XLT, FX4 etc..), but a FX4 cluster will definately fit in an XLT. Thanks for any info you might be able to give me here. |
xlt cluster to Fx4
https://cimg9.ibsrv.net/gimg/www.for...7225ff47ee.jpg
https://cimg6.ibsrv.net/gimg/www.for...56b82fcca7.jpg https://cimg5.ibsrv.net/gimg/www.for...0bc119cf80.jpg I just replace my 2007 f150 XLT cluster with a FX4 and had no problems.It was plug and play. Everything work just fine.No programming needed.Take's about an half hour to do.I also change the stock black face to white.I took the time to sand off the green tint so that it would light up white.I installed white leds and it looks great. |
Originally Posted by KINGS11
(Post 14842405)
http://cimg9.ibsrv.net/gimg/www.ford...7225ff47ee.jpg
http://cimg6.ibsrv.net/gimg/www.ford...56b82fcca7.jpg https://cimg5.ibsrv.net/gimg/www.for...0bc119cf80.jpg I just replace my 2007 f150 XLT cluster with a FX4 and had no problems. It was plug and play. Everything work just fine. No programming needed. Take's about an half hour to do. I also change the stock black face to white. I took the time to sand off the green tint so that it would light up white. I installed white leds and it looks great. I prefer black faces and white numbers, etc .... but that's just a personal preference thing .... and it's not saying the white face looks bad because it looks great on that set .... but I really like the night shot. :-X22 . |
My XL f150 has a built in tach. Hold the trip reset button before you put the key in, keep holding it as you put the key in and start it. flip threw a few options and a digital tach comes up. Gotta do that every time. So i know i have a tach sensor, just not on the cluster.
did you make the swap at the end.
the trouble your talking about was with the lariat digital climate control. ac wouldnt work. i did mine no problem just the millage changed. |
We can correct the mileage to be accurate on the new cluster if you want. Just call us at 800-547-2049 if you want to talk through the options.
Originally Posted by CircuitBoardMedics
(Post 16480363)
