Turn Signal for F-150 Won't Reset
What is the procedure for replacing a turn signal mechanism in the steering column? Mine doesn't automatically reset after completing a turn.
Thanks for your help. Craig |
Craig,
I haven't done this myself, but here goes: 1)Disconnect Battery Ground cable. 2) Remove ignition switch lock cylinder. 3) Twist the Tilt wheel Handle and remove 4) Move Gear Selector to lowest position. Release 4 Clips and remove Steering column opening cover. 5) Remove upper and lower Steering Column Shrouds. (three screws on the bottom) 6)Remove Multifunction Switch (Turn signal stalk and switch) There are two screws and one electrical connector. Good Luck, Bill |
