Thanks, but I am going to let Ford figure it out. It is covered but it is just a huge inconvenience. It seems that the art of mechanicing is going and all the service technicians do plug your vehicle into a computer and do what it says. Somethings still have to be learned/done by ear/touch.
I have a 2004 F-150 and this cam phaser issue has been aweful for me. The first sign for me was ticking then the vehicle wouldn't idle unless I disconnected one of the phaser sensors. The first dealership I took the vehicle into told me I needed a new engine $6000. The second said I need need the phasers replaced $1500. Before I could get the money rounded up the vehicle just died and would not start. A buddy and I pulled the valve covers (very hard) last weekend. When we pulled the left phaser out we found out the pin on the back of the phaser had sheared which I guess means the left side has jumped time. UGH!!! I guess I am going to pull the front timing cover and re-time and hope for the best.
Please feel free to comment on this. Does this mean I have to pull the head on that side? |
5.4lit VCT Cam Phaser Video
Greetings everyone!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
The VCT Phaser replacement takes about 6 hours for an experienced tech. You must have the 2 special tools required to perform the job in that time, the valve spring compressor and the timing chain wedge. Without the tools, the front cover would have to come off. There is a procedure and it requires that the rockers be removed to keep the cam from rotating. <o:p></o:p> Watch my video and you will get the idea!<o:p></o:p> §ŕṂàşṫęřṪệčħ <o:p>VCT Phaser video</o:p> <o:p></o:p> |
Nice!!! Thanks for the video.
Tick, Tick, Tick
CAM PHASERS! AAAHHHH!
My "04" F150 with 75,000 mi. does sound like a diesel. That is how I have been describing it to people. After reading all these forum posts I see that I am not the only one with this probliem. I am still unsure though if the noise is just annoying or will be harmful to my truck that could lead to permanent motor seizure. Yes noise does come from passenger side, but mechanic says noise goes away when engine is revved over a certain rpm. What should I do? Change cam phasers or leave it alone? Please help.:-wink |
Replace the Phaser
Originally Posted by jade.lusk
(Post 8532223)
My "04" F150 with 75,000 mi. does sound like a diesel. That is how I have been describing it to people. After reading all these forum posts I see that I am not the only one with this probliem. I am still unsure though if the noise is just annoying or will be harmful to my truck that could lead to permanent motor seizure. Yes noise does come from passenger side, but mechanic says noise goes away when engine is revved over a certain rpm. What should I do? Change cam phasers or leave it alone? Please help.:-wink I recommend that you replace the Cam Phaser. I had a customer that declined to repair is rattling Phaser and about 7 months later, I was replaceing the engine because the Phaser came apart causing valve to pistion interface. |
I have the same engine and I believe my bank 2 sprocket is off one tooth, causing the engine to run rough and die- I can disconnect the cmp sensor and it runs fine- is there a way to tell if it is off like the mark between the 2 copper links?
Timing
Originally Posted by khackr
(Post 8914919)
There is now way for you to tell by the plated links. The Cam Phasers have stuck before, but if it changes by unplugging, I would test the electronics to see the something in the computer or wiring in causing the concern. |
My noise is at start up not a idel, under load until you go under load 1/4 to 1/2 mile then it stops until the next restart not disel sound more like a tap or squeek on the passenger side
this started on my 1999 at about 80,000 is this a cam phaser?
Originally Posted by y-block head
(Post 8991256)
Thanks I have seen this in other threads, is there a cure other thank piston replacement
Originally Posted by SrMasterTech
(Post 8920810)
I am stumped. |
i have to replace the phasers on my dads 05 screw he has drove it around for about month with it running like crap (not idling). this is how it started.He took it to tire rama in spokane to change the oil he has been running royal purple oil in since the day he bought it new. about 5 blocks down the road it started to run really rough so he took it back and they wouldn't do anything for him so he had to wait a week until he could have ford look at it.Ford said it was the phasers so i have been researching on how to fix these and have a few ????
1) with him driving it for so long im worried that the pin on the back of the phaser may have broke and i will have to take the front cover off. Is there a way to tell if the pin has broke other than taking it all apart (it runs fine at high rpms) if the pin is broke is there a way to realign the motor and and not have to remove the front cover? 2) Is there a aftermarket phaser to put on? i really dont want to install a oem phaser that will have the same problems that original one had. 3) if i do use a aftermarket lockout phaser do i have to use a chip? any input would be awsome ps i dont think this will be much fun my 7.3L dsl is not as complicated as this thing |
Originally Posted by Rudeman
(Post 7894742)
I took my '05 in for a ticking noise and was told it was the phasers. Got them replaced (paid a $100 deductible) and the noise came back. Took it back in they've had it for two days; said they had a guy come in from Ford to look at it. Now they tell me it's the lash adjusters. And...since it is a different part/service they are charging me an Additional $100.
WTF!! The service guy said that they must have backed off after I took it home. The noise was not there when I first fired it up but it got progressively louder and when I dropped it off it was as loud as when I took it in the first time. Does this sound like a load of chit or what? I figure that as long as the covers are off and you're working on the engine because of valvetrain noise wouldn't you check the valve lash since the noise is nearly indistingushable from cam pahser noise? |
