Need Help Body Lift On 95 150 With 300 6
What Do I Need To Do To Make The Lower Raidator Hose Fit?
ummm, longer hose? lower your core support/radiator?!!?!?
-cutts- |
We got it to work with a 3inch on a f150, we just had to put it on the lower barb, then zip tie it back from the pulley. just make sure its secure.
You need an Autozone Radiator Hose P/N 883769. It's not a molded hose but it will fit just fine. I would suggest that you cut your old hose and use it as a chaff guarg for the new one, where it touches the frame.
Good luck Kevin |
