Is the intake for a 4.6L the same as a 5.4L?
Not real familar with the Ford "modular" engines and what interchanges between the 4.6 and 5.4. It seems that I have the dreaded coolant leak from the crossover tube on the 5.4 in my '99 Expy. I'm handly enough with the wrenches so after looking over the procedure, I'm gunna give it try. So I've been poking around and haven't had much luck ID'ing a replacement intake. I have come across a couple that were listed for a 4.6 and that's what has brought this question up.
The rig has 112K on it and other than this leak and a couple other minor 'tweaky' things, it runs great!! Thanks in advance! Scott in Texas |
No,the 4.6 and 5.4 are not the same.They look the same but the 5.4 is a taller block therefore the 5.4 intake is wider then the 4.6.
I have a 5.4 intake off of my 03 if you need one. Took it off when I did a Lightning conversion. Phil |
Wow...Thanks for the quick reply, Phil! I appreciate the offer on the intake. PM me and we'll work out the details.
I have a 5.4 intake off of my 03 if you need one. Took it off when I did a Lightning conversion. Phil really? the one I took off my 2001 F150 5.4L has the ford sticker that says 4.6/5.4L so i would've thought they were the same. if anyone else needs the stock setup, let me know....i put the K&N Series 77 intake on mine. |
Originally Posted by rsylvstr
really?
the one I took off my 2001 F150 5.4L has the ford sticker that says 4.6/5.4L so i would've thought they were the same. if anyone else needs the stock setup, let me know....i put the K&N Series 77 intake on mine. The air intake may very well be the same. Phil |
I think hes talking about the intake (manifold)!
