Lightning belt change?
I have a 200 Lightning and I need to change the belt on in. The supercharger belt was easy i just cant figure out the regular belt. How to you take off the crank pulley for the supercharger and the braket behind it. I need help fast!! I have an embarrasing squeak that needs to go ASAP...thanks
the bracket is held on by 1 bolt and 2 nuts, remove them and then get a 14mm hex socket and spin the pully off the harmonic balancer. Installation is the reverse but make sure you put some antisieze on the threads before you re-install it.
Alright thank you, that thing is a little tricky, got me a little confused!
also I forgot to tell you that it is a left hand thread and that you may have to keep the engine from rotating because I believe it is torgued down to 100ftlbs. Good luck and glad to have helped ya.
