Low Speed Miss
130k MILES, USES A LITTLE OIL, HAS NOT BEEN ABUSED. I have picked up a low speed miss which is worse when cold. Runs good under power. Really bad when I first start. thanks for the help. JDS549
Sounds like a weak or partially clogged injector to me.
Would a partially clogged injector cause a code to set? Just wondering.
I am not showing a code...... Jerry
My 99 is doing same thing ... more noticeable after a long haul and you stop at a red light ... feels like im semi bouncing up and down ... stick shaking about 1/4 inch .... not as noticeable while accelerating but seems rougher than what i once thought was normal vibrations .... I tried a bottle of "GUMOUT Diesel Fuel Injector Cleaner" a couple of weeks ago to see if i would notice any difference .... it acuallt seemed to be getting worse.... on top of that i have noticed a small leak on driveway... smells like oil (just noticed it today) this may be from loose oil filter.. just recently had it replaced.
How many times and how often should i run a bottle of diesel kleen through it to make sure i have them kleen .... they have never been cleaned (128K miles) |
