Will this work?
I have 3 thirty gallon steel drums that I want to use to start making my own bio. My plan is to heat wvo in one over a propane grill type flame, at the same time I'll mix my lye/methanol in a 5 gal bucket. Once the oil is warm enough (150 degrees?) I'll pour in the methoxide and blend it (three hours or so?) and then let it settle over night. The next day I'd drain off the glycerin from the same original drum and then mix in magnesol in 2% by weight since I'd rather not go through the extra step of washing it. I don't have a way right now to recover the methanol (any suggestions?) so I guess I can store the glycerin in the second drum till I rig up a still or something. How does this plan sound? I'm open for suggestions or advice cause I don't want to piss off the wife by blowing up the house LOL. Thanks!
FABMANDELUX. :-X25 :-fire |
Quick ?s for you fabmandelux, why store the glycerol on sealed buckets, it left open the methanol will evaporate correct? Also, 150 deg F is above the evaporation point of methanol, (yes Iv'e read your formula and know you have been doing this for years this way), but still a fact is a fact. When you do your processing, do you process in a closed system, which would not allow evaporated methanol a way of escape?
Originally Posted by phish555
Quick ?s for you fabmandelux, why store the glycerol on sealed buckets, it left open the methanol will evaporate correct? Also, 150 deg F is above the evaporation point of methanol, (yes Ive read your formula and know you have been doing this for years this way), but still a fact is a fact. When you do your processing, do you process in a closed system, which would not allow evaporated methanol a way of escape?
I understand, thanks for explaining that to me. Im thinking of raising my processing temp a hair. I currently use 135 F. I add my methoxide so slow though, I don't really notice a drop in temp. I use a mechanical temp gauge.
Fabman- I plan on making small batches of around 20 gallons at a time using the formula you gave me before in correct proportions- any idea how long a 120v heater would take to heat this up?
Cool, thanks. I'm getting there.....
Originally Posted by fabmandelux
Yes and no:) The drums will work just fine. DO NOT use an open flame for a heat source around the biodiesel process! You can use either a 120 VAC or 240 VAC water heater element installed in the drum to do your heating. If you heat to 150 deg F you should only have to mix for 30 min if you use mechanical mixing. If you use a pump to mix you'll have to mix for a longer period. If you pump from the mix tank to an elevated holding tank right after mixing you will be able to drain off the glycerol from the bottom of the drum the next day, BUT ONLY IF YOU USE KOH! If you use NaOH you will have to deal with a solid glycerol..........not fun to remove out of a closed drum [don't ask me how I know:mad: ]. The glycerol can be stored in SEALED 5 gallon buckets till you can make a recovery still.
FABMANDELUX. :-X25 :-fire You talk about mechanical mixing reduces your time vs. pump mixing. Do you know the difference in time? I'm looking to have a processor built by spring. I really like the Appleseed because it looks cleaner than an open system. I have many busy body neighbors and a hot water tank sitting in my garage will not draw as much attention. Has anyone added a mechanical mixer to a hot water tank? or would the direction of the bio coming into the tank change the mix time, maybe a coil of pipe in the top the will cause the bio to stir in a whirlpool format? At what point do you know when there has been enough mixing? Thank Dane |
I was thinking about using a drill with a long paint mixing "bit" to mix everything. Or is there something easier or better to use? Also, I need to weld bungs or through pipes in the bottom of the barrels, should 1/2" fitting and pipes be best to use?
I was thinking about using a drill with a long paint mixing "bit" to mix everything. Or is there something easier or better to use? Also, I need to weld bungs or through pipes in the bottom of the barrels, should 1/2" fitting and pipes be best to use? When you drain off the glycerin, do you just slowly drain it until it comes out clear like the bio or do you siphon off bio first?
Originally Posted by DanE.
Hey FabMan,
You talk about mechanical mixing reduces your time vs. pump mixing. Do you know the difference in time? I'm looking to have a processor built by spring. I really like the Appleseed because it looks cleaner than an open system. I have many busy body neighbors and a hot water tank sitting in my garage will not draw as much attention. Has anyone added a mechanical mixer to a hot water tank? or would the direction of the bio coming into the tank change the mix time, maybe a coil of pipe in the top the will cause the bio to stir in a whirlpool format? At what point do you know when there has been enough mixing? Thank Dane Openstyle/w mechanical mixing: 30 minutes................:-D Seeing if you have a complete reaction.....PRICELESS! An open style processer can be "cleaned-up" by adding a little sheetmetal. FABMANDELUX. :-X25 :-fire |
Been there, tried that:mad: I use a 1/4hp 120vac electric fan motor [scrounged 0$] with a piece of 7/8" shaft. I just drilled a 1/2" hole in one end for the motor shaft, and the mixing blade?..........................an impeller from and old "302" FORD water pump:-D I would start with 1" bungs, you can always use a bushing, and it's real hard going larger. My "receiver" tank has a pipe in from the top for pumping out the bio. I drain off the glycerol from the bottom drain first, then pump out the bio through a 6 micron filter. There is always about 2" of bio left in the tank because the suction pipe is about 4" off the bottom. FABMANDELUX. :-X25 :-fire |
Methanol + Spark (from drill motor) = BoomJust be carefull. Maybe use a closed motor (drill) if there is such a thing.
How much glycerin can be expected if I'm only maxing about 25 gallons of fluid? I want to put my suction tube deep enough so that I don't leave too much bio just lying unused. Also, can the whole process be done in one drum? Or is it best to heat and mix in one and transfer to a second one?
