Ford Truck Enthusiasts Forums
-   The Next Generation (https://www.ford-trucks.com/forums/forum177/)
-   -   Update on my Nova 385 series supersport :) (https://www.ford-trucks.com/forums/551985-update-on-my-nova-385-series-supersport.html)
385seriesHemi 11-28-2006 10:08 AM
Well ive changed my mind a lil on some parts
1. Milling heads .020/ porting also
2. flat top pistons with cast iron rings not moly rings
3. Lunati camshaft with .542/ .552 (1,400 - 5.700 rpm)
4. Fel-pro .041 thick head gasket (OEM is .066 thick)
5. 2 inch carb spacer open bore
6. Edelbrock intake 1,500 - 6,500 open bore
7. Ford racing timing gear set
8. Holley Double pumper 750 cfm (stock CFM)
9. Custom headers since its goin in my nova but I dont kno what size tubing to use yet
10. Debating on bore size also its either stock or .030 over
Dont kno what size valves to use either because the intake ports of the D3 heads are fine but the exhuast is lacking.
This car will be going to car shows and will be saying Powered by Ford on the hood
385seriesHemi 11-29-2006 04:27 PM
I think i will put a 4 speed behind it maybe even a 5 speed transmission who knows
Beast12 11-29-2006 05:22 PM
Sounds like a great project. :-X22
-Matt :-tap
qwik88 11-29-2006 10:49 PM
did you have that car at ffw in new hampshire last year
385seriesHemi 11-30-2006 12:01 PM
nope, its been under construction for 2 years so far its as custom as custom gets
qwik88 11-30-2006 12:03 PM
o there was 1 with a ford motor up at ffw last year
385seriesHemi 11-30-2006 12:34 PM
yeah well thats kool, i cant wait to see the chevy guys faces when i open my hood lol
