12.52
Ran a new best of 12.52@108.9mph 1.85 60' also ran a best of 110mph trap speed. If anyone is interested in a couple videos, i can pm you the links. For some reason the mods always remove them from my posts.
Injectors are comming back out in a couple of hours, swapping nozzles out for something bigger. Im also going to be customizing my nitrous system a bit more by adding a second solenoid and a progressive controller. This is only a single stage controller so i will use 2 solenoids for 1 big shot. Calcs put me at a little over 650rwhp on the gas, shooting for 750+ when everything gets put back together. |
Dang....not bad bad for a rattling old work truck. ;) :-X22
For some reason the mods always remove them from my posts |
I would also like to see those links
you two should have a PM
congratulations. shoot me a pm with those links when u get the chance, please. what size injectors are you using? what turbo?
You should have a pm also.
Im running BDP/ FFD custom DT 530's. They are 275cc's and have been flowed and balanced (stock is 90cc's or so). Im running a hypermax h2 mounting kit with a bdp modified h2e. |
hmm that is strange, the site that those are on must be on the "black list" since its another forum. I'll try and email them to you.
I sent you an email. |
sign me up.
ok i tried a PM (which i dont think went through) and also sent an email, so lemme know if for some reason you dont get the links.
Luke |
