NEED Fuse panel diagram
91 ford aerostar...turn signals dont work.....need fuse panel diagram..not sure if it is the blinker fuse or the main fuse
Replace both the fuses and check the relay. But first check the emergency light switch under the steering column. If it is not pushed up well, turn signals dont work.
Fuse Panel — Aerostar
https://www.ford-trucks.com/user_gal...134697&width=0click for fuse panel pic AEROSTAR FUSE PANEL Fuse Position Amps Circuits Protected 1 15 Amp Fuse Hazard Flasher, Stoplamps, Indicator Lamps, Speed Control, Brake Shift Interlock 2 6.0 Amp C.B. Windshield Wiper/Washer 3 — Not Used 4 15 Amp Fuse Side Marker Lamps, Headlamp On Warning Chime, Under hood Lamp, Daytime Running Lamps (DRL), Parking Lamps, License Lamps, Instrument Panel Illumination, RABS "Keep Alive" 5 15 Amp Fuse Turn Signal Flasher, Air Bag Module, Backup Lamps, DRL Module, Rear Defroster Switch, Turn Signal Indicator, Brake Shift Interlock 6 20 Amp Fuse Speed Control Amplifier, Warning Chime Module, A/C Clutch, Door Ajar Relay 7 20 Amp Fuse Rear Anti-Lock Brake System (RABS) Module 8 15 Amp Fuse Illuminated Entry, Stepwell Lamp, Cargo Lamp, Power Mirrors, Courtesy Lamp, PSOM, Clock, Glove Box Lamp, Visor Vanity Lamps, I/P Courtesy Lamps, Dome Lamp, Reading Lamps 9 30 Amp Fuse Aux. A/C, Front A/C Blower Motor 10 15 Amp Fuse Air Bag Module 11 15 Amp Fuse Radio, Amplifier 12 30 Amp Fuse Power Lumbar, Flash to Pass, High Beam Indicator, Horns 13 5 Amp Fuse Instrument and Control Illumination 14 20 Amp C.B. Power Window Motors 15 15 Amp Fuse A.W.D. Module and Indicator 16 20 Amp Fuse Front Cigar Lighter, Rear Cigar Lighter 17 10 Amp Fuse PSOM 18 15 Amp Fuse Warning Chime, Instrument Cluster, Rear Wiper Motor, Rear Washer Pump Fuse Block Bracket 4.5 Amp C.B. Rear Wiper Motor, Rear Washer Pump |
