Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum41/)
-   -   1960 F100 rebuild/restore (https://www.ford-trucks.com/forums/54305-1960-f100-rebuild-restore.html)
jwcnj45 09-24-2002 04:34 PM
ragmans60 09-28-2002 08:44 AM
I've been reading these messages and it seems that there are alot of you out there that have been through what I am now beginning to start. I have a big back window, short bed, stepside 1960 F100. I want to:
1. install 351W or 351M
2. install C6
3. rewire
4. install power disc brakes at all corners. i don't want to change
ride height because... well, just because.
5. install power steering
6. install new steering column
7. redo interior
8. paint
My question is this: In what order should I do these mods to be the most efficient? The truck is not running now. Of course I know to do the mechanical before paint and interior, but what should I do 1st, 2nd, 3rd, etc.? Thanks for any input.
Jimbare 09-29-2002 12:07 AM
i would start with the steering and the brakes at the same time.
then move on to the engine-tranny swap.
then the wiring.
then the paint and body.
and last but not least, the interior.
darkhorse54 09-29-2002 03:46 PM
Ragmans60,I-would-do-it-in-the-order-you-mentioned-except-for-7-and-8-because-it-sounds-like-you-want-to-upgrade-your-steering-and-brakes.
ragmans60 10-01-2002 05:00 PM
thanks for the input. sounds like a good plan. i'll post my progress.
